Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F700 Check Codes
Old Nov 6, 2018 | 10:41 AM
CJWisinski's Avatar
CJWisinski
F700 Check Codes
Hi, I have a 1994 F700 429 efi and the check engine light comes on about 45-60 seconds after starting evey time i start the truck. I have the eec connector under the dash on the passenger side and it has the little individual wire with it. I found several videos online about how to self test by jumping terminals or grounding the little wire etc. but none for this truck in particular. Any advisement on this would be greatly appreciated, thank you!
Old Nov 7, 2018 | 06:25 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Hopefully someone comes along with answers for you soon. WELCOME to FTE!
Old Nov 7, 2018 | 07:34 AM
projectSHO89's Avatar
projectSHO89
The procedure will be the same as any other Ford OBD1 vehicle.
Old Nov 7, 2018 | 09:23 AM
CJWisinski's Avatar
CJWisinski
Okay could anyone tell me the proper procedure? All of the videos I watched did it differently
Old Nov 7, 2018 | 09:26 AM
85e150's Avatar
85e150
Got this one?
https://www.scribd.com/doc/34996350/...-and-Procedure
Old Nov 7, 2018 | 09:41 AM
CJWisinski's Avatar
CJWisinski
Originally Posted by 85e150six4mtod
That one is different because what I saw had you jumping the small connector to a pin in the large connector. I know my check engine light itself works so I will try later. That test is for KOEO is there another procedure for KOER or do those codes not really matter?
Old Nov 7, 2018 | 11:56 AM
projectSHO89
Either works as long as the grounding system is not compromised. Signal ground = chassis ground, that connection is made either at or in the PCM module.
The previously provided link only went to a subset of the old Ford Fuel Injection website. You can see the complete contents of that site now at Fuel Injection Technical Library including the KOER testing procedure.
Old Nov 7, 2018 | 12:13 PM
CJWisinski's Avatar
CJWisinski
Okay thank you. I had a chance to try the koeo test and I grounded the STI to the negative battery and nothing happened. Turned the key on and the truck went through its normal sequence of fuel pump prime and a relay click along with all of the dash lights come on. But the check engine light just stayed solid. I then took my test light and ran it to the positive battery and touched the STO terminal and it did not light. Any suggestions to try from here?
Old Nov 7, 2018 | 01:13 PM
projectSHO89
Ground the STI connection to the signal ground pin in the EEC-IV connector per the instructions and see what happens.
Old Nov 7, 2018 | 02:14 PM
CJWisinski's Avatar
CJWisinski
Grounding the STI to the EEC connector on the SIG pin does not do anything. All dash lights stay on just like when grounding the STI to the battery
MONAVIERONJON
Sep 9, 2009 07:06 PM
lennb01
May 14, 2009 04:56 PM
boggerted
Mar 29, 2009 09:27 PM
crackerloco
Mar 28, 2007 07:22 PM
downunder1
Oct 31, 2000 02:07 PM
