1969 Crewcab 4x4 build
Those switches are out of some older large truck, ie: KW, Pete, etc. Most had lighted switches and marked for what they were for. If you want something similar you will likely have to dig in a big truck junkyard. There is plenty of new stuff available, but depends on what you want it to look like.
cstoyer I took your advice and checked O'Reilly. They had to order them but they did ask to see if they had metal pistons. They arrive tomorrow and if they are rebuilt Daytons then I am good to go. I had checked several places already with no luck and I also checked several places online including Rock Auto which has a large selection so I was surprised That O'Reilly had them ! even my Napa didn'
Thankst
Thankst
The caliper locating pin (2B296 in pics) shearing their threaded portion off was never solved.
Upper pic: 1968/71 & 1972 before serial number M80,001.
Lower (upper) pic: 1972 from serial number M80,001.
Every thing got blasted over the last few days and then yesterday a friend came over and helped me prep and prime all of my axle components . I used a 2 part black epoxy primer which turned out a lot glossier than I anticipated.
Allmost all of my rebuild parts have arrived and I am looking forward to the rebuild. When it is together I may shot it with a matte black.
#28
I purchased the 7/8 allen socket from 4wdfactory.com It is for a 3/4 ratchet or breaker bar. I live about 20 miles from their shop so i just drove over and bought it. It was $28.00.
My axle was already removed so i chained it to a forklift so it wouldn't move and used my 3/4 ratchet with a 3' cheater pipe. I had to really pull but it came out with out heating it up.
#30
Yeah I bought the king pins and removal tool, 7/8 hex material, from East Coast Gear last week. I have heard everything from heating the kingpin to undercutting the kingpin head to take the stretch out of the threads to help with removal. I'll just need to find something to strap it against and get out the big cheater bar and 3/4 breaker.
CStoyer
