1969 Crewcab 4x4 build
#61
So Truck is almost completely disassembled , the front clip , hood and bed have all been dustless blasted and primed , 03 lariat seats modified and installed, headers installed on mock-up block with built NV 4500 and 3" stainless dual exhaust fabbed , cross members and steel surround for 33 gallon rear mount plastic tank fabbed.
Best of all is a crazy sexy 496 cubic inch cross bolted side oiler FE motor waiting to bring the beast to life.
I know I know No pictures No Proof I will attempt to update this thread in the next few days with plenty of pictures ! 😊
#63
#64
CStoyer
#69
When I bought the truck it was running and driving and I started upgrading things. Some of the first were power steering and power disc brakes. I was enjoying the heck out of driving my beast but knew that the plan was to make a road and road trip worthy daily driver with modern safety and amenities. I had originally contemplated a diesel swap. That changed when I got the Marti report I saw that there were only 524 crewcab 4x4 trucks made in 1969 and mine had factory air!!! I started to rethink that plan and started looking for an FE motor. I Have been driving diesel fords since 1997 and am spoiled by the torque and power especially since I pull trailers all the time. I knew that if I was going to happy with a gasser it would have to have TORQUE and power. At the point in this journey that these photos were taken I had found a 1969 428CJ motor that I had planned on using.
#70
Years ago I built 66 ranchero that would pull the front wheels of the ground. It was running a 390 with a 428 crank and 427 medium riser heads with 427 dual quad manifold. It was a VERY fun car/truck !! So i have had some experience building high performance FE stroker motors. Fast forward to now and I came across a company called Survival Motorsports , they are experts on all things FE . They build motors and sell parts and even have their own line of cylinder heads. One of the things I saw on their site was stroker kits and that planted the seed. The plan for the 428CJ was to use a Scat 4.250 stroker crank and rods with would yield 465 cubic inches of FE mightiness ! lots of stroke = TORQUE with a side order of power !! I was waffling back and forth between using the CJ heads or Edelbrock aluminum heads . Having had and fought to tune a dual quad set up I wasn't heading down that dark path again, I want hop in and go drivability so after much deliberation decided to use and Edelbrock tuned port injection set up. So with a numbers matching 1969 428CJ out of a GT Torino I took the engine to the machine shop to do their magic and got myself a junk 360 block so I could mock up the tranny and build the exhaust.
#71
You should put a doubler in front of the NP205 and triple stick it. With a 5.61 1st (NV4500), 1.96 from the NP205 and either a 2.0 or 2.7 (NP203 or Behemouth Drivetrain with BW gears) a doubler would put you at least at a 22:1 ratio before your axle. Could be a lot of fun as a crawler. I plan on running the Torque splitter (over drive), NP435 (6.2 1st gear), Behemouth Drivetrain doubler with BW gears (2.7:1), and a NP205 (1.96:1) transfercase. So 5 stickshifts for a total of 32 gears if I wanted it. HA! But really, with 4:10 gears and 40" tires, crawling with a ratio of 134:1 will be fun.
#72
Barry does great work! I had him machine the block I'll be using for my 71 restomod. It's a 390 stroked out to 444 cu. in. with Edelbrock heads and their Pro-Flo 4 EFI system. I went with a Lunati Hyd. Roller cam for the lower end torque, so it should be a fun motor. Keep the posts coming, you're doing well on your build.
#73
Cool build. Sucks about the 429, but glad to see you are still working on it. I'll be watching what you do moving forward. I've got a F-100 standard cab 4x4, but have the similar goals. Not going to go as extreme on the engine, but plan to have a stout 410 or something in the future and am considering the same transmission & transfer case combo.
#74
So is the motor a 496 or a 465?
A lower rpm torque build or high rpm hp? Are you going to port the edel heads? What cam? Looks like the edel PF4 is a single plane (victor) manifold for high rpm use.
Perhaps I'm a little jealous of such a bad *** FE...
Why the divorced t-case? you have gone so far with everything else.
#75
Smoky
A couple posts up I stated that I had a 428 CJ that I planned on using. After a few weeks waiting in line for some attention at the machine shop I got disappointing news. When they did a sonic check for wall thickness , I was not comfortable with doing a high HP build with that block. When I say High HP My goal is 600+ HP with 625 Torque . So the search for a High HP FE continued.
Much sadness ensued both emotionally and to my wallet.
The end result is currently 496 Cubes
I will post pictures of the MEGA FE that I got soon. It is not usable for my purpose in its current state . The motor was in a 7 or 8 second mustang , full race 14 to 1 compression .800 lift intake and exhaust Ports big enough to swallow your arm or at least small gophers!!
