1978 - 1996 Big Bronco
1995 302 V8 idle at startup
Old 11-09-2018, 12:37 PM
n9lhm's Avatar
n9lhm
n9lhm is offline
1995 Bronco, 302 V8, fast idles at the wrong times. Often it will not fast idle after cold startup and you have to manually fast idle it for a few seconds to keep it running. After a few seconds, no problem. Often at hot starts it revs up to 2000 RPM or more when it doesn't need to. Runs great all the rest of the time. Already changed the IAC. Anybody seen this? Is there some temp sensor that tells it when to fast idle that is bad? Or something else?
Old 11-10-2018, 05:46 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Check your codes to start with, see what your computer knows.
There are Air & Water Temp Sensors, also the MAP & TPS sensors affect idle.
Did both of your issues start at the same time?
Disconnect you IAC next time it high idles to see if it drops.
(yes, I read you installed a new one)
GGraves
11-11-2016 08:29 AM
FlyCool5.0
02-21-2015 01:46 PM
Jamie987
04-03-2010 08:25 PM
c96drumm
09-01-2006 09:51 AM
MJB
Bronco II
10-22-2003 03:38 PM
Quick Reply: 1995 302 V8 idle at startup
