Bronco II Ford Bronco II
Erratic Idle
Old Oct 20, 2003 | 08:36 PM
MJB's Avatar
MJB
Question Erratic Idle
My 86 Bronco II has a problem with idle. After warm up the idle kicks down to around 1400 rpm. After additional driving the idle will move down to 1000 RPM. It's supposed to be around 800 RPM. The idle will wander on occasion by a few hundred RPM up or down. This makes the vacuum reading wander between 17 and 20 inches. The Haynes manual wants to check every flippen thing in the circuit. I know it's just one probelm causing this. Any ideas out there?
Old Oct 21, 2003 | 12:09 PM
Ken00's Avatar
Ken00
I would start by cleaning the IAC.
Old Oct 21, 2003 | 03:11 PM
_rich_'s Avatar
_rich_
Clean the IAC; disconnect the wire to it and see if the idle changes (it should); check for vacuum leaks; check for codes. Is that every flippin' thing?
Mine runs at 1500 or so for a few seconds when first started, then drops to around 1100 for a couple minutes. After 4 minutes or so, it idles at 800. The only problem I've had that affected the idle speed was a bad ECT sensor (engine coolant temperature). That made for a consistent high idle because the computer thought the engine was always cold.
Old Oct 21, 2003 | 09:13 PM
MJB's Avatar
MJB
Well that figures. My temp sender is bad. I was going to change the gauge to a manual type. I didn't know that the computer got temp info from that sender that also feeds the temp gauge.
And IAC? What is that? And I have no codes. Being in Florida the engine warms up fast. It idled at 1000 rpm's all day untill I got the A/C working, then the idle dropped to 800.
Old Oct 21, 2003 | 09:39 PM
MJB's Avatar
MJB
Of corse I'm using the factory tach to measure RPM's.
Old Oct 22, 2003 | 12:06 PM
Ken00's Avatar
Ken00
IAC =idle air control valve.
The computer has its own temperature sensor, it has two wires, the gauge's has one wire.
Old Oct 22, 2003 | 03:38 PM
_rich_'s Avatar
_rich_
If it's the ECT (as Ken00 said, NOT the same as the gauge's sensor), the computer should show a code for "ECT out of range" or something similar. But take the IAC off and clean it up first. It's the horizontal cylinder mounted near the top of the upper intake on the passenger side.
If you have to replace the ECT - a word of advice. Grab the vaseline and go to the dealer.
When my ECT went out, I went down to Pep Boys and bought another one. The old one was all metal, bronze colored. The new one was plastic. It lasted 6 months. Then I went to NAPA and paid more money for their ECT. I asked if they had an all-metal one. Nope, just this plastic one. It lasted 6 months. The third time, I went to Ford, paid an obscene amount of money and got an all-metal, bronze colored ECT. It's lasted over a year so far.
Melansk
Dec 6, 2025 07:45 PM
thefox48
1997 - 2003 F150
Nov 4, 2015 01:12 PM
JayzDaddy
May 11, 2015 06:36 PM
nosebreaker
Mar 29, 2011 08:09 PM
Surf Fishn Truck
1978 - 1996 Big Bronco
Oct 25, 2008 08:03 AM
