1995 302 V8 idle at startup
1995 Bronco, 302 V8, fast idles at the wrong times. Often it will not fast idle after cold startup and you have to manually fast idle it for a few seconds to keep it running. After a few seconds, no problem. Often at hot starts it revs up to 2000 RPM or more when it doesn't need to. Runs great all the rest of the time. Already changed the IAC. Anybody seen this? Is there some temp sensor that tells it when to fast idle that is bad? Or something else?
GGraves
11-11-2016 08:29 AM
FlyCool5.0
02-21-2015 01:46 PM
c96drumm
09-01-2006 09:51 AM
