6.2 Unicorn
Old Nov 6, 2018 | 10:43 AM
  #31
crewzer's Avatar
crewzer
Thumbs up
Originally Posted by PentaPop
The truck camper crowd likes those 6.2 duallys. Gives them a higher payload rating than a heavy diesel.
Our truck must be a cousin to the Unicorn. It's an F350 CCSB SRW 4x2 6.2 4.30 with the camper package and a 3912 payload spec (limited due to low load capacity of the 275/65R18E A/S tires). We use it to haul our truck camper.
We were at Huntington Beach State Park in SC early last week:
Regards,
Jim / crewzer
Old Nov 6, 2018 | 11:01 AM
  #32
Alaskan_Warbird's Avatar
Alaskan_Warbird
Originally Posted by Busa 1 Dave
Hmmm an edge sport. Yes that is a beast. This is one of my cars after the builder got finished with the motor the first start. Need sound and this one WILL set you back in the seat. I am about performance so that is why I have the oil burner period. Cost is not a concern but extended idling in hot desert at the ranch is more than pulling. If I lived in Alaska---yes maybe a gasser...
https://www.ford-trucks.com/forums/1...l#post18288971
Nice! I bet that thing MOVES.
And to be clear, I don't poo-poo the 6.7 diesel. It's a heck of a platform and has it's place. I just don't like it when guys on either side start whipping out these completely false numbers or otherwise try to make themselves feel good about their purchase. My situation is very specific - I'm extremely picky and know what I want. Side note: I also run full synthetic in my 6.2 gasser. Not only to hopefully increase engine life, but because we do cold weather camping and the truck sometimes gets started after sitting for days at temps well below 0 F, without being plugged in. I need to know my rig will always start, w/o a bunch of work or the need for a generator to warm it up first.
Old Nov 6, 2018 | 11:04 AM
  #33
Alaskan_Warbird
Originally Posted by Clubwagon
Yeah, I shoulda' seen this coming. I just wanted to post a picture of what I thought was a cool and rare truck.
I ain't knocking anybody for their choice. I just wanted to post a pick for the 6.2 fans out there.
And thank you for posting it. It looks like my truck's twin and it was a pleasure to see.
Old Nov 6, 2018 | 11:58 AM
  #34
Busa 1 Dave's Avatar
Busa 1 Dave
Warbird---After thinking about this more there is no question if I was in Alaska or maybe Buffalo for example no question it would be gas for me. Reliability if nothing else---never have to worry about frozen DEF for example.... Yes I know there is a heater...
Old Nov 6, 2018 | 01:15 PM
  #35
troverman's Avatar
troverman
Frozen DEF is no problem - it's frozen fuel that causes the problem! Found that out last year. I love these trucks, gas or diesel. I've had both, diesel for now, maybe gas next time. 7.3L gas engine is pretty interesting. But the 6.2L is really a great engine.
Old Nov 6, 2018 | 01:50 PM
  #36
Alaskan_Warbird
Yeah, I have buddies who've had their diesel gel up on them. Heck, the last really cold winter we had probably 10-15 years back, a bunch of people's home heating oil started gelling up and their homes started freezing up. It hasn't been that cold here in a long time, tho.
Old Nov 6, 2018 | 02:03 PM
  #37
Busa 1 Dave
I thought DEF became frozen solid at 10 degrees and slush about 12?? Know it has a heater as the fuel does -- my point was in cold cold be nice not to worry about that issue...
Where I go in NM MAY get into single digits a few times a year but in DFW not hardly ever.
Leave the truck out overnight at a hotel say -10 below then have to drive 500 miles in that temp or worse could get sporty...….
Old Nov 6, 2018 | 02:05 PM
  #38
troverman's Avatar
troverman
DEF freezes at 12F as you say...but the truck runs fine without it while the heaters work to unfreeze it. I don't believe your engine is idled for a DEF heater issue, so even if they failed you'd still be OK.
Old Nov 6, 2018 | 02:08 PM
  #39
Busa 1 Dave
Interesting--maybe it was my Cummins that would go into limp mode if the DEF froze and it called for a regen. This is a good thing to know...
Old Nov 6, 2018 | 02:12 PM
  #40
troverman's Avatar
troverman
DEF is not part of the regen process, so not sure what you mean there. Some trucks have the SCR (DEF) mixer tube ahead of the DPF; some have it after. On our Fords, it is before. During regen, the goal is for maximum exhaust temps to cook the particulate in the DPF. Injecting an ambient-temp liquid into the exhaust stream before the DPF would serve to lower temps, so I believe DEF injection is paused during regen cycles.
Now, if you run out of DEF, or the DEF is deemed to be poor quality or "not DEF" (such as water), then your truck will be idled.
Old Nov 6, 2018 | 02:56 PM
  #41
Busa 1 Dave
GOOD LORD Yes! The DEF is not part of the regen in the "engine" however, is injected into the exhaust to clean out the particulates which the regen adds fuel to make heat to burn and clean out the filter. It would stand to reason that and actually Cummins delays this for an hour(allow the DEF heater to work) if below 10 degree at start, not having DEF for 500 miles would overload and trip sensors putting you into limp mode as if there was no DEF present ie run the tank out. I do not think the regen process will take place with no DEF in the system. Does that make sense?? Maybe someone with more knowledge can explain better.
Old Nov 6, 2018 | 03:19 PM
  #42
Dim Sum's Avatar
Dim Sum
I have high hopes for the 7.3L and 10 speed. Unless there are signficant changes to diesel emission systems, fuel costs or the 7.3s performance / reliability....I can easily see it being what's in my next truck (if it really saves 8-9k in purchase costs).
Old Nov 6, 2018 | 04:21 PM
  #43
troverman's Avatar
troverman
DEF is not injected to “clean out the particulates” but rather is injected to reduce NOx emissions. Lowering NOx emissions is the sole purpose of DEF. Without DEF, you’d need more EGR to bring NOx down, along with a richer mixture. Both lower fuel economy, so DEF solves the NOx problem with significant fuel economy penalty.
Now the EPA is very strict about NOx (see VW TDI) and that is why your truck will idle if you run out of DEF or run non- DEF in the tank. I don’t believe your truck will be idled for frozen DEF because of failed heaters, but I could be wrong. I see no reason a regen couldn’t happen without DEF...my 50hp Kubota tractor performs regens same as my truck and doesn’t use DEF at all.
Old Nov 6, 2018 | 04:24 PM
  #44
Boasty's Avatar
Boasty
I'll never understand why diesel costs more in the states. It's cheaper in Canada and why shouldn't it be it's a by product of gas
Old Nov 6, 2018 | 04:45 PM
  #45
Clubwagon's Avatar
Clubwagon
Low Sulfur diesel and taxes.
https://en.wikipedia.org/wiki/Fuel_t..._United_States
