Dash clock
Old Nov 4, 2018 | 11:27 PM
bobs 80 f250's Avatar
bobs 80 f250
Dash clock
Had to replace battery. Now I can’t reset my dash clock. Push the buttons to reset time and date, but it won’t change. It’s been difficult before, but now it’s impossible. Any help is appreciated
Old Nov 5, 2018 | 01:23 PM
reamer's Avatar
reamer
The button contacts "corrode". Push hard and wiggle them to get a good contact.
Old Nov 5, 2018 | 02:02 PM
R/S85's Avatar
R/S85
Just ran into this just this past weekend. Yes do try to push "hard" or wiggle them around. If that still does not yield results, remove the radio bezel, remove the entire clock assembly, then take a very slim piece of sandpaper and wedge the sandpaper between the flat silver piece that is raised off the back of the circuit board that is between the buttons and the circuit board. The buttons push this flat, very small metal piece down and it makes contact on the back of the circuit board to change time, date, etc. I tried the wiggle and push method before and worked, but until this past weekend (time change) it no longer worked. After I used the sandpaper to knock off the corrosion on the metal tabs, I was good to go!
Old Nov 8, 2018 | 03:10 AM
crucialprospect's Avatar
crucialprospect
Have to try this in my truck, bought a jy unit and it’s never been easy to change date/time!
rrcrum
2009 - 2014 F150
Mar 30, 2015 04:39 AM
Anafiel
Feb 9, 2014 07:04 PM
Douglas DC-9
Sep 10, 2009 09:12 AM
Carnivore
2004 - 2008 F150
Jul 20, 2004 08:46 PM
dnmyoda
16
Feb 9, 2004 12:42 AM
