how do i set my clock
Old Jan 11, 2004 | 03:36 PM
dnmyoda's Avatar
dnmyoda
Question how do i set my clock
i have an 86 f150 with the factory clock in the dash above the radio does anyone know how to set this thing i have tryed all the buttons and cant get it iam thinking of unhooking the battery until 12:00 so that it is right
Old Jan 11, 2004 | 03:54 PM
86f15035s's Avatar
86f15035s
just hold the time button then press the little buttons to the right of the time button. the left one is for hours and the right one is for the minutes.
Old Jan 13, 2004 | 07:30 PM
dnmyoda's Avatar
dnmyoda
unfortunetly none of the buttons will due anything but i have bigger problems now anyway but thanks for the help
Old Jan 13, 2004 | 09:40 PM
DanMartin's Avatar
DanMartin
Hmm...me too. No combinations of the buttons seem to work for setting the console clock. Seems logical enough to hold the time button down while pressing the other two buttons on the right, but nothing happens (yes, I even tried pressing hard).
Anyone have the answer to that one? Could it be an alignment problem with the clock board behind the dash cover and the buttons maybe not making contact correctly?
Old Jan 13, 2004 | 10:15 PM
otto's Avatar
otto
i think your not pushing hard enough, possibly try some contact cleaner, can you set the date or start the e.t. recorder ?
The other guy said he had bigger problems maybe he blew his engine ?
Old Jan 13, 2004 | 10:16 PM
Bronco81XLT's Avatar
Bronco81XLT
push them all you want, youll be there a while . you have to pull out the time button. then set it with the 2 tiny buttons. then push the time button back in.
Old Jan 13, 2004 | 10:32 PM
DanMartin's Avatar
DanMartin
Talking
Ugh...
http://www.umount.com/~danm/gifted.jpg
Old Jan 13, 2004 | 11:17 PM
howler's Avatar
howler
Talking
cool, I appropriated the interior from an 85' donor truck, and have been scratching my head looking for info on clock adjustment...
many thanks,
howler
Old Jan 14, 2004 | 05:30 PM
otto's Avatar
otto
the pushbutton does not get pulled out, once again it is a push button
Old Jan 14, 2004 | 06:46 PM
jhardin's Avatar
jhardin
I have an 86 F-150 with the exact same clock and buttons. You Push and Hold the Time button, then use the 2 buttons on the right to set the hours or seconds. Same method with the Date button.
Pushing harder will Not help. Push lightly and wiggle the button gently to scratch through some of the corrosion.
Old Jan 14, 2004 | 07:58 PM
82F100SWB's Avatar
82F100SWB
Here's the entire 3 page section form my 84 Ford Shop manual:
http://www.bigblocksix.com//f100swb/...ff/clockp1.jpg
http://www.bigblocksix.com//f100swb/...ff/clockp2.jpg
http://www.bigblocksix.com//f100swb/...ff/clockp3.jpg
Old Jan 14, 2004 | 08:32 PM
rainbowATF's Avatar
rainbowATF
shop manual sets record straight on setting clock. maybe whats missing from some of the previous thread instructions is step #1: ignition switch must be in ACC or ON position in order to make adjustment
Old Jan 14, 2004 | 10:47 PM
dnmyoda's Avatar
dnmyoda
thank for the help other problem turned out to be a gas slush puppie due to the cold weather here in newengland and a hole in my tank
Old Feb 6, 2004 | 12:48 AM
blackstinky's Avatar
blackstinky
when your fingers start to bleed you can except failure, but until then get the clock set.
lol
Old Feb 6, 2004 | 08:20 PM
dnmyoda's Avatar
dnmyoda
took it out of dash contacts are all clean will let you know when i get it back in
