Need EGR Supply Tube Help
1995 F250 460 Auto. Been searching but, can't find. Looking for the tube that runs from the right side exhaust manifold (held in by 2 bolts), to the left side manifold where it is threaded to a connector in the Manifold. At least that's what I was told by the exhaust shop. There is another tube with threaded fittings on both ends that runs from the manifold to the EGR valve. That tube seems readily available.
Help please.
Thanks, George
Help please.
Thanks, George
Guy said he had to cut the right side in order to get the manifold off. Of course trying to find one...F3TZ9B480F Greensales doesn't have one.
Around $300 for the left side tube and up to $120 for an elbow. Going out in a bit to check with the garage.
This was one reason I didn't want to get into the job, knew it would be a PITA. I can see why a lot delete the system.
bansheeduner
02-17-2008 04:59 PM
