Need EGR Supply Tube Help
Old 11-02-2018, 03:00 PM
GLR's Avatar
GLR
GLR is online now
1995 F250 460 Auto. Been searching but, can't find. Looking for the tube that runs from the right side exhaust manifold (held in by 2 bolts), to the left side manifold where it is threaded to a connector in the Manifold. At least that's what I was told by the exhaust shop. There is another tube with threaded fittings on both ends that runs from the manifold to the EGR valve. That tube seems readily available.
Help please.
Thanks, George
Old 11-02-2018, 03:12 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Are you talking about the AIR injection tubes, that go to the smog pump?
Old 11-02-2018, 03:40 PM
GLR's Avatar
GLR
GLR is online now
What I was told, it's a tube that runs from the back of the rt manifold to the back of the left manifold. Having trouble finding a diagram which would help.
Old 11-02-2018, 04:23 PM
GLR's Avatar
GLR
GLR is online now
Old 11-02-2018, 05:32 PM
GLR's Avatar
GLR
GLR is online now
OK, think I might be getting it. Rt side pipe must go to Air pump
L side goes to air pump . There are 2 connectors on manifold. 1 for pipe that goes to air pump other to EGR valve. I think. Wish I was near the truck so I could check it out.
Old 11-02-2018, 07:01 PM
GLR's Avatar
GLR
GLR is online now
Got it figured out, finally. Google had a link to and old 2011 thread that didn't show on FTE search. Showed pics. Now to find parts.
Turns out I was mis-informed by the guy working on the truck. Now I'm getting a little worried...
Old 11-03-2018, 09:17 AM
Lead Head's Avatar
Lead Head
I'd verify which pipes are actually broken.
Old 11-03-2018, 09:36 AM
GLR's Avatar
GLR
GLR is online now
Guy said he had to cut the right side in order to get the manifold off. Of course trying to find one...F3TZ9B480F Greensales doesn't have one.
Around $300 for the left side tube and up to $120 for an elbow. Going out in a bit to check with the garage.
This was one reason I didn't want to get into the job, knew it would be a PITA. I can see why a lot delete the system.
jle70
05-15-2016 09:18 PM
Truck Guy99
13
10-27-2013 06:14 PM
sgmcdaniel
02-20-2009 12:32 AM
bansheeduner
02-17-2008 04:59 PM
Quick Reply: Need EGR Supply Tube Help
