I'm about to cry...
Old Nov 1, 2018 | 02:23 PM
Fordrocks689's Avatar
Fordrocks689
I'm about to cry...
I thought my luck was bad before... it just got worse,
While trying to get #3 injector out the screw bit slipped off and fell into the engine.
I heard it hit metal... if there was anytime I needed your guys help... it's right now
Old Nov 1, 2018 | 02:26 PM
SoCal-Bob's Avatar
SoCal-Bob
Telescopic magnet is probably your best bet. Sorry to the bad news.
Old Nov 1, 2018 | 02:28 PM
Fordrocks689
I drained the oil, hoping there was a god that would let it just fall out... It was wishful thinking. Would it have fallen into the cylinder?
It fell right where the light is, Name:  photo459.jpg
Old Nov 1, 2018 | 02:38 PM
SoCal-Bob's Avatar
SoCal-Bob
If it went into the injector sleeve, it's either on a piston or a valve.
Old Nov 1, 2018 | 02:43 PM
Fordrocks689
Can that be fished out?
Old Nov 1, 2018 | 02:50 PM
SoCal-Bob's Avatar
SoCal-Bob
Possibly, with a magnet. Maybe a pickle claw if you know exactly where it's at. That would require the use of a telescopic camera.
Old Nov 1, 2018 | 03:02 PM
Fordrocks689
Came to the auto store, renting one right now.
Old Nov 1, 2018 | 03:06 PM
SoCal-Bob's Avatar
SoCal-Bob
Good luck! Keep us informed on your success.
Old Nov 1, 2018 | 03:28 PM
joe blow's Avatar
joe blow
Worse case you take the valve train off to get you more room. If the bolt fell in, it will only go as far as the piston/cylinder....and it will be toward the outside since it sits at an angle.
I am sure you'll find it
Old Nov 1, 2018 | 03:53 PM
TooManyToys.'s Avatar
TooManyToys.
The question will be did it go down the injector tip hole or down the oil return?
Only you know the size of the bit to know if it will make it through the injector hole.
One of these should help.
Amazon Amazon
I think it was RustyA who pulled the pan to recover one of these.
Old Nov 1, 2018 | 03:55 PM
TooManyToys.
https://www.ford-trucks.com/forums/1...turn-hole.html
Old Nov 1, 2018 | 04:00 PM
Fordrocks689
Amazon Amazon
It went down the hole closest to the glow plug, the injector was still bolted in when it came loose.
Old Nov 1, 2018 | 04:10 PM
Fordrocks689
No luck using the camera. So the question now is how do I pull the pan, praying it would be in there
Old Nov 1, 2018 | 04:16 PM
Fordrocks689
Thanks guys, I'm going to take a break for a little, eat something and cry a bunch. Then I'll take out the pan... 😭
IT WAS SUPPOSED TO BE A SIMPLE INJECTOR JOB DAMNIT!!!!
Old Nov 1, 2018 | 04:57 PM
SoCal-Bob's Avatar
SoCal-Bob
Try the camera again. If the injector wasn't out, then there's a good chance it's in the valley, maybe hidden by the valve springs
