Torx bit down oil return hole
Old Jul 11, 2018 | 07:12 AM
crazyjpeters's Avatar
crazyjpeters
So I was torquing down my injectors. The bit came out of my holder and fell down the rearmost pass oil return in the head. Sounded like it slid all the way down to the oil pan but fishing around for it I just can’t locate it. I’m thinking it landed on the upper oil pan plate.
would you drop the pan for it or just hope it works its way down to the bottom of the oil pan? I’m pretty sure the pickup has a trash screen.
Old Jul 11, 2018 | 09:30 AM
JaySVX's Avatar
JaySVX
I'd get a long flexible magnet and run it down the hole and see what you can find. If not, I'd drop the pan. Definitely don't want that bouncing around. Chances are you'll be fine, but I wouldn't want to risk it over a hundred bucks.
Old Jul 11, 2018 | 11:09 AM
navistarnut's Avatar
navistarnut
Could always get or rent a borescope to poke around and see if you can locate it and retrieve it.
Old Jul 11, 2018 | 11:41 AM
TooManyToys.'s Avatar
TooManyToys.
$25-35 gets you a borescope that will work with a cell or pad.
If it’s on the windage tray it runs the risk of contacting a rod throw if it’s turned and heading to the pan. If it’s in the pan it’s inert.
I would spend the few dollars and hunt with a scope first. You’ve got several holes to go down through.
Old Jul 11, 2018 | 12:33 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I had bent a small handless screwdriver into a J shape to pry out the glow plug connectors from the inside (valve cover off). It was workin great until I dropped it into the oil return on the back of the passenger side head. I wanted someone to say it would be ok but nobody here would say it, lol. As bad as I hated it, I dropped the pan and the tool was in the bottom. It wasn’t that hard except getting the engine lifted off the mounts if you are 4wd. The front axle is right in the way for lifting at the crankshaft balancer. In the end I cut some wood scrap “just so” and managed to get it high enough. Anyway, it would have bothered me to leave it and you are probably the same way. You’ll hear a little rattle every time you crank it and wonder if this is it.
Old Jul 11, 2018 | 02:58 PM
crazyjpeters
The rocker box edge blocks the return hole. Otherwise I’d peek down there with a Boroscope. I couldn’t find it with anything so my assumption is it’s sitting on a windage tray or upper oil pan.
Old Jul 11, 2018 | 04:22 PM
TooManyToys.
There a lot of open in that upper pad, but I know with my luck. If you drain all the oil out and smack the bottom of the oil pan you might be able to hear it bounce. The drain hole has a post for the threads so if it’s down in that area you can’t get it out by hunting through the drain hole. Could be on top of the pickup too.
deersticker
Feb 24, 2011 09:33 PM
powerstroke1869
Jun 3, 2010 04:55 PM
mattri
Colorado Chapter
Jun 15, 2004 09:26 PM
