Deep vibration/ shutter at 60mph+
Old Nov 1, 2018 | 09:10 AM
94FIRSTF150's Avatar
94FIRSTF150
1994 f150 4x4 4.9 I6 5-speed regular cab. The vibration starts at 60-65 mph and gets worse if I keep accelerating. Vibration stops instantly when I let off the gas even when going over 75 mph; that makes me think it's not the tires (even though it could use some new ones). I don't feel it in the steering wheel and it's like a deep noise, kinda like letting out the clutch when you accidentally shift to overdrive from 2nd gear. Is it an ignition issue? Driveshaft? Rear end?
Old Nov 1, 2018 | 09:45 AM
Robert Long's Avatar
Robert Long
Check fuel pressure,also check injectors. have you pulled codes?
Old Nov 1, 2018 | 11:11 AM
94FIRSTF150
I already have a new fuel pressure regulator I'm planning on installing soon, but how do I check the fuel injectors? What do I look for?
Also, no I have not pulled codes.
Old Nov 1, 2018 | 11:21 AM
Robert Long
There are some good videos on you tube with step by step instructions. but first pull codes.
Old Nov 1, 2018 | 11:24 AM
94FIRSTF150
Thanks I'll keep you posted
Old Nov 2, 2018 | 12:43 AM
892504x4's Avatar
892504x4
Check the u-joints!
Old Dec 12, 2018 | 08:43 AM
94FIRSTF150
Originally Posted by 892504x4
Check the u-joints!
It was the u-joints! Finally got time to change them. Now I can do 65-75 mph no problem at all
Dave042
2009 - 2014 F150
38
Jun 25, 2024 10:35 AM
kbuchheit
Mar 29, 2013 11:45 PM
Firealmond
15
Dec 1, 2012 12:31 PM
FordMan35
Oct 23, 2012 10:25 PM
1L243
Mar 29, 2011 07:46 PM
