Heavy vibration/shudder
Old Dec 1, 2012 | 06:43 AM
Firealmond's Avatar
Firealmond
Trailering
My 1997 F350 4x4 (107,000 miles, 5 spd) developed a heavy vibration while driving cross country last night. The symptoms are most severe at low and high rpms. They moderate but are still present at 65 mph. The vibration is also present while stationary. The truck visibly shakes. I suspect the clutch is going out but there did not seem to be any slippage. Any ideas?
Old Dec 1, 2012 | 06:56 AM
96ford250's Avatar
96ford250
Where is the noise coming from the tranny or the engine?
Old Dec 1, 2012 | 07:43 AM
Firealmond's Avatar
Firealmond
Trailering
Not really any noise, just severe vibration. It was severe enough to have it towed the 75 miles to my house last night. It seems to be coming from the engine area but I can feel the vibration when I put my hand on the shifter lever.
Old Dec 1, 2012 | 08:01 AM
96ford250's Avatar
96ford250
Any codes? And how is the vibration when you sitting still and rev it up a little does it get worse?
Old Dec 1, 2012 | 08:22 AM
Red97350's Avatar
Red97350
DMF coming apart? Do you have any mods to the truck? Ohh and welcome to FTE!
Red
Old Dec 1, 2012 | 08:23 AM
Firealmond's Avatar
Firealmond
Trailering
At idle it runs rough, when i rev to 1500 rpm's there is a horrible vibration/shudder.
No codes as of yet.
Old Dec 1, 2012 | 08:24 AM
Firealmond's Avatar
Firealmond
Trailering
No modifications to the truck. I have owned it since it was new.
Old Dec 1, 2012 | 08:26 AM
96ford250's Avatar
96ford250
I would look at your flywheel I agree with red
Old Dec 1, 2012 | 08:27 AM
Red97350's Avatar
Red97350
Does it clunk when you shut it off?
Red
Old Dec 1, 2012 | 08:38 AM
Firealmond's Avatar
Firealmond
Trailering
No clunk when I shut it down.
Old Dec 1, 2012 | 11:21 AM
richdawg's Avatar
richdawg
Sounds like DMF going to me, I had very similar symptoms when mine went. Remove the inspection cover that covers the flywheel, very easy to remove. this is a pic of what I found in the bottom of mine.
This is where the parts came from, The missing parts causes severe vibration due to the out of balance flywheel.
It is not a very good Idea to drive very far with this problem, possible for the flywheel to come apart and that could cause severe carnage.
Old Dec 1, 2012 | 11:47 AM
Firealmond's Avatar
Firealmond
Trailering
Transmission is cracked from near starter motor to top of transmission.
Old Dec 1, 2012 | 11:58 AM
richdawg's Avatar
richdawg
Is it for sure the trans thats carcked? Is it leaking Oil from the crack?
Old Dec 1, 2012 | 12:05 PM
Firealmond's Avatar
Firealmond
Trailering
It is in the bellhousing area - about a 16 inch crack.
Old Dec 1, 2012 | 12:12 PM
richdawg's Avatar
richdawg
That's good it not the tranny. Did you remove the inspection cover yet? You need to do that, but it really sounds like a flywheel/clutch has done the damage.
