PCM Diagnostics Help Please
Old Oct 31, 2018 | 08:34 PM
Wes444's Avatar
Wes444
Just showing you my pcm and the numbers associated with it. Also that a DAC2 is in a DPC 421 family
Old Oct 31, 2018 | 09:13 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
IIRC the DPC-421 is the PCM hardware family, aka has all the proper pins and physical internals, while the DAC2 or whatever is the tune. As long as the family is correct the engine will run fine, especially with a ZF6. With 4R100 the tunes matter more since they might be for the MT or the AT.
Old Oct 31, 2018 | 09:33 PM
timmyboy76's Avatar
timmyboy76
I thought CNN covered the ABC, that was until FOX "Trumped" NBC...
Dont care what the rest say about you Colorado, ur aight in my book
Old Oct 31, 2018 | 09:47 PM
Silverhks's Avatar
Silverhks
No constructive comments but I got you guys covered on the Rep
Old Oct 31, 2018 | 09:55 PM
Colorado350's Avatar
Colorado350
Wait for it…
Old Oct 31, 2018 | 10:06 PM
BBslider001's Avatar
BBslider001
Oooook dudes, here's your dipchit story of 2018 to share with all your friends. John still rules...I do not.... apparently.
Years of OBS ownership had me looking at the wrong #30....under the hood....not under the dash.
Beers on me everyone....and a free ride in my super awesome truck that is now operational once I get more fuses...yeah, I am out of those too.
Old Oct 31, 2018 | 10:08 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Nice, easy fix and free beer!
Old Oct 31, 2018 | 10:18 PM
Silverhks's Avatar
Silverhks
Easy fixes are the best. When you miss them at first it just makes you feel better, later after the "I'm an idiot" light goes out.
Edit: oh, and don't forget to unplug the fuel bowl heater before trying to start the truck.
Old Oct 31, 2018 | 10:19 PM
BBslider001
To answer your question, I have no answer yet. But, this has lit a fire to get a spare and send it the guy in Tennessee that rebuilds them. When I do figure out, I'll definitely share it.
Old Oct 31, 2018 | 10:23 PM
Colorado350
I think when you plugged the fuel bowl heater back in, it was just a matter of time before the fuse blew. I wrapped my plug in red electrical tape to kinda create a moment of reflection as to why the tape. You can also rebuild the FBH but from what I’ve it’s not worth the money especially since you’re Western bound.
Old Oct 31, 2018 | 10:36 PM
BBslider001
I agree. That plug will stay disconnected.
Old Nov 1, 2018 | 07:36 AM
Walleye Hunter's Avatar
Walleye Hunter
Are you telling me that I failed to log the appropriate information/code for my pcm when it was out of the truck?
ForScan will give you that information, Sous.
Old Nov 1, 2018 | 09:00 AM
  #28
Sous's Avatar
Sous
FTE Emeritus
The next time I have Forscan going, I will see if I can identify the code. I will not be pulling the PCM just to get a picture of the code though, that is for sure. The part number for my PCM and the one Wesley posted are identical though, not sure if the part numbers for all PCM's are the same with different codes or not.
Old Nov 1, 2018 | 03:40 PM
  #29
Stewart_H's Avatar
Stewart_H
Originally Posted by BBslider001
Thanks my friend. I'd send it to him in a second if I knew I could get it back pretty quick.
He has a one day turn-around.
Wait until you get older and all the vehicle related stuff in your head gets even more jumbled. Sorta like recounting the story to someone during a conversation where my Gen 2 Lightning was stolen and stripped back in '01, only to finish the story and realize, it was my 1990 5.0 Mustang GT that was stolen and stripped, not my Lightning.
Stewart
Old Nov 1, 2018 | 05:33 PM
  #30
coax9952's Avatar
coax9952
Mick Jagger said it best....." What a drag it is getting Old".
