E4od code 629 help
Old Oct 30, 2018 | 09:02 PM
ShindaChinmoku's Avatar
ShindaChinmoku
E4od code 629 help
Hey yall im having a problem with my truck and thought somebody might want to chime in. i have a 1994 f150 with the 5.o e4od transmission. It dies whenever i put the truck in drive, ive replaced the torq converter solenoid pack and the iac. if anybody could help it would be great
Old Oct 30, 2018 | 09:21 PM
timbersteel's Avatar
timbersteel
A 1994 302 usually would be mated to a 4R70W. Are we sure it's an E4OD that we are working on?
Maybe Code 629 is directed to an E4OD, I'm not sure.
What is the trans code on the door pillar?
Old Oct 30, 2018 | 09:22 PM
ShindaChinmoku
its E, plus on the crossmember says e4od
Old Oct 30, 2018 | 09:28 PM
ShindaChinmoku
Old Oct 31, 2018 | 09:52 AM
ShindaChinmoku
if anybody has something i could try please feel free to say something i need my truck back
Old Oct 31, 2018 | 10:14 AM
Scndsin's Avatar
Scndsin
Converter clutch circuit failure.
Check wiring & plug at the right rear of trans that frequently gets damaged along with the wiring up to the computer.
Dirty connections, pins backed out, melted or abraded wires.
If it were mine, I'd pull the computer & inspect for leaking capacitors.
Does the speedometer needle jump by any chance?
Old Oct 31, 2018 | 10:38 AM
ShindaChinmoku
No not at all, the thing is if you disconnect the battery for awhile and plug it back up you can put it down into first, but once you go to second the rpms drop and when you go to drive it idled like at 500 and sounds like it wants to die, but once you get going down the rode it does good, but then the code comes back and you can’t do nothing with the truck.
Old Oct 31, 2018 | 11:01 AM
Scndsin's Avatar
Scndsin
"Most " E4 issues reported here over the years are electrical in nature rather than parts failures, but hard part fails do occur.
Personally I had mine rebuilt because I was sure it was about to catastrophically fail.
In the end, it was leaking caps & a failing PSOM issue on top of that.
I was getting TC clutch codes, then slipping where the rpms would increase with the truck slowing, then NO codes at all.
What kind of mileage are we talking about? Is the fluid dark/dirty or burned smelling.
(edit) if pulling the bat cables restore some function & replacing the solenoid pack did nothing, I be more sure that the problem is in the computer, but others may say different.
Hopefully you'll get another opinion.
Old Oct 31, 2018 | 11:04 AM
ShindaChinmoku
The egine has about 212000 miles on it but about 10 thousand miles I had a front main seal on the transmission replace and they went over the entire transmission components because off the limp mode occurring sometimes when you drove the truck.but they said everything was fine
Old Oct 31, 2018 | 11:14 AM
Scndsin's Avatar
Scndsin
Well in that case mechanical failure is certainly possible.
Old Oct 31, 2018 | 11:18 AM
ShindaChinmoku
but it when I drive it it’s perfectly fine, it was owned by my dad before me and he replaced the transmission when it had 120000 thousand miles and it didn’t do much towing or anything just the occasional drive to town or to haul something. Also the fluid was bright red before I changed it and the filter
Old Oct 31, 2018 | 11:21 AM
rla2005's Avatar
rla2005
When is the Code 629 being displayed? KOEO or Stored Code?
Are there any other codes displayed?
Old Oct 31, 2018 | 11:34 AM
ShindaChinmoku
Koeo it displays 629 and that’s it, when the engine is running their are no codes
Old Oct 31, 2018 | 12:06 PM
rla2005's Avatar
rla2005
As David stated, the connector on the solenoid end has known to get contaminated with grease/oil/moisture. When you checked the solenoid pack did you give it a good inspection? Also verify the pins are in good condition and fully seated in the connector. I believe there is a connector, C103, located on the driver side fender well liner that is a junction point between the computer and the transmission. That is a spot to also inspect.
From there you could have a bad connection at the PCM, computer, or as David suggested the computer itself could have a problem. It's a process of elimination.
Old Oct 31, 2018 | 12:22 PM
ShindaChinmoku
Yeah I’ve inspected the pins and they look good I’ve also used electric cleaner and cleaned them and used dielectric grease to make a good connection I’ve also traced the wires back and they look fine.
the c103 connector what does it look like
