6.2L V8 Discuss the 6.2L V8
6.2L Stalling
Old Aug 23, 2020 | 02:44 PM
  #31
Todd layman's Avatar
Todd layman
6.2 stalling
Originally Posted by wilfredo.s.lara
Yeah the owner at the shop is trying to convince me it’s the throttle body. I had already taken that out and cleaned it but it is electrical so it’s really hard to tell. I just don’t want to spend 600-700 to replace a throttle body for it not to be that and it seems like those electric throttle bodies are hard to come by.
its not the throttle body. I changed it and still stalls. I also changed both temp sensors all 02 sensors and purge valve. still stalling
Old Dec 6, 2020 | 02:32 PM
  #32
Todd layman
stalling
update. my truck has gotten worse. I have changed the torque converter and trans. just changed the pcm. now it will only run with a charger on it. battery tests good. it will still stall at 165 temp. any one have any idea why its doing this. thank you
Old Dec 7, 2020 | 07:03 PM
  #33
Ron94150's Avatar
Ron94150
Did you change the purge valve that was mentioned at the beginning of the thread? One of the more common issues on these trucks.
Old Dec 7, 2020 | 07:28 PM
  #34
Todd layman
yes that was my first thing. I changed both temp sensors,intake gasket,throttle body,pcm,torque converter,transmission, no luck. niw it will only run with charger on the battery. if you take the charger off it will stall. if it hits 165 temp it will stall. thanks you for responding. I really appreciate it.
Old Dec 24, 2020 | 02:30 PM
  #35
Todd layman
6.2 stalling
. I finally got it to run. it turned out to be the crankshaft positioning sensor.. I found an article online that said it can go bad without setting off the cel. it will cause stalling when it warms up do to the coils inside expanding. I wish I found this esrlier on it would gave saved me 5k. I hope this saves someone alot of time and money
Old Dec 24, 2020 | 10:11 PM
  #36
Rootpass's Avatar
Rootpass
It’s been a long trip but I’m glad you found out what it was. Thanks for keeping all of us updated!
Old Dec 24, 2020 | 10:15 PM
  #37
Todd layman
stalling
yes that was the first thing I changed. I changes the torque converter. cam sensors,02 sensors,temp sensors,pcm,throttle body.. it would still stall.. I changed the crank sensor and now it runs great
Old Feb 28, 2021 | 08:21 PM
  #38
markmcj's Avatar
markmcj
Just to throw this out there. I too had an issue with my truck stalling when putting it in gear.
This would happen after the cold start high idle would drop but before the engine was at operating temp.
It would always start right back up once it stalled.
I also had OBDII codes for the cam sensors, replaced those with no change, cleaned the throttle body, no change.
I found this thread, swapped the crankshaft position sensor, problem solved.
Runs great, shifts better and idle RPMs are more consistent.
Old Feb 28, 2021 | 09:01 PM
  #39
Todd layman
Originally Posted by markmcj
Just to throw is out there. I too had an issue with my truck stalling when putting it in gear.
I'm glad my results were able to help others. this is what makes this forum so great
Old Oct 31, 2021 | 01:19 PM
  #40
Devin patton's Avatar
Devin patton
Locaion
Can anyone tell me the location of the crankshaft position sensor? 2012 F250 lariat 6.2
thanks!!
Old Oct 31, 2021 | 03:46 PM
  #41
markmcj's Avatar
markmcj
thanks!!
2011 6.2L - the crank sensor is on the very back of the block, driver side.
I read the intake has to be removed. Which I did.
If I ever have to do it again, I would try to take a serious look and double check if there is clearance to get it out with the intake manifold on. There just might be.
Be careful installing the new one, it needs to go in at the correct angle..
Total time for the service was approximately 2.5 hours.
Good luck.
Old Nov 1, 2021 | 11:38 AM
  #42
Devin patton
Good luck.
I appreciate the help. I'm going to take a hard look at it this afternoon. So I'm assuming I need to get to it from under the car? is it even visible if looking under hood?
Old Nov 1, 2021 | 12:43 PM
  #43
markmcj's Avatar
markmcj
You will not even get close to it from under the truck.
It will have to be from the top.
​​​Using a mirror, you'll be able to see it. If you try to get it out without removing the intake, it will be by feel.
Old Dec 15, 2021 | 09:37 AM
  #44
3Bros's Avatar
3Bros
how do you find out if it need updates
Old Feb 16, 2023 | 07:28 PM
  #45
marc57's Avatar
marc57
Trailering
Thumbs up
I know this thread is old but
Just wanted to say Thanks to everyone who posted here.
After reading this thread, got my truck fixed.
Stalled only when cold, would start right back up. Ran after warmed up.
No codes.
It Was The Crankshaft Position Sensor.
Did it yesterday took 4-1/2 hours runs perfect.
Oh it was a 2012 f250 6.2, 110800 miles on it.
