Weak battery question
Old Jan 10, 2019 | 10:55 AM
knottyrope's Avatar
knottyrope
an item with highest resistance in a series circuit will have the highest wattage
I didn't know OHMs law back then.
Old Jan 11, 2019 | 07:46 AM
Jarrett Campbell's Avatar
Jarrett Campbell
You might be able to do a ship to store on a 850 cca if you're really set on getting Walmart power under the hood lol
Old Jan 11, 2019 | 10:36 AM
BBslider001's Avatar
BBslider001
Those Ever-Starts really aren't bad for the coin if you can't drop life savings on an Interstate or other rep brands. I have used them, both for my truck and for my RV and they haven't failed me.
Old Jan 11, 2019 | 10:44 AM
Tedster9's Avatar
Tedster9
Originally Posted by fluidp
Im having same issues with my wood truck, 94 f250 with a 95 PSD Was not starting after sitting a few days. I determined that one of my batts was pooched. They are both 850cca batts. Since its only used for wood in summer and moving sled around in winter I can't justify spending $350 on batts right now. I do have 3 brand new deep cycles sitting in my shop. two 27 series and one 31 series 12V. Im gona put in the 27's under the hood and the 31 in the back hooked up through a solenoid for when I have my camper on. They are lower in CCA's but with all three in parallel, they should be more then good enough to turn her over. Heres Hoping lol
Can you justify spending money on a battery charger? Do it! That's something that usually seems to be missing on these annual battery discussions, everybody wants to know what the "best" battery is for the money but it won't matter what is installed if chronically undercharged, it simply won't last nearly as long as it should. A good charger will pay for itself many times over.
Old Jan 11, 2019 | 10:52 AM
bagman1995's Avatar
bagman1995
I had an issue with my driver side battery having a 12.3 charge. Passenger side would charge and drain into the lower voltage battery so I did not notice until one day it did not start. The terminals all "looked" clean, I even wire brushed them and slapped on some petroleum jelly. However when I tested with multi meter I found that passenger side battery was not getting a charge to the terminals but the driver side was. I tested the connection from the alternator to the battery cables and they read 14+ volts so there was obviously charge going to the cables it was just not charging the battery. A metal bristled pipe cleaning brush and replacing the cable bolts was all it took and it started charging right back up. It did not look corroded, just an idea
Old Jan 11, 2019 | 11:15 AM
knottyrope's Avatar
knottyrope
I mentioned invisible corrosion in my link.
Old Jan 11, 2019 | 11:30 AM
bagman1995's Avatar
bagman1995
This is why I have to read everything... Sorry for the repost
Old Jan 11, 2019 | 12:41 PM
knottyrope's Avatar
knottyrope
no worries, sometime I don't have read it all and do the same
Old Jan 11, 2019 | 12:48 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Shiiiiiiiiiiiit. I use AZ golds.
I would use Odyssey if the ol' wallet allowed.
green_95
13
Nov 12, 2018 04:01 PM
Realslowww
20
Jan 3, 2016 08:31 AM
privateer, eh
Jan 24, 2014 07:12 AM
bulletpruf
16
Jun 17, 2010 12:41 PM
jeff7825
Sep 6, 2009 02:07 AM
