Battery voltage question
Old Sep 5, 2009 | 04:41 PM
jeff7825's Avatar
jeff7825
What should good batteries test while the truck is not running? And what should they test while the truck is running? I tried to do a quick search, but didn't come up with much. Thanks guys. I am trying to find out if my batteries are weak or not.
Old Sep 5, 2009 | 06:08 PM
clintbonnie's Avatar
clintbonnie
The voltage with the truck not running should be around 12.5 volts.. using a digital voltage meter.. Not a very good test however. Running should be about 14.4. I like to check my batteries with a hydrometer occasionally.. It will show the condition of each cell.. If any are weak, I replace the battery.. (note: battery must be fully charged to do this test..) Napa sells a good battery hydrometer for around $20..
Old Sep 5, 2009 | 06:10 PM
agg_bagg's Avatar
agg_bagg
alot of places will test your batteries for free. you need to do that because a battery can have the right voltage but fail a load test.
Old Sep 5, 2009 | 10:12 PM
jeff7825's Avatar
jeff7825
Thanks for the help guys.
Old Sep 5, 2009 | 10:21 PM
jcrammell's Avatar
jcrammell
What is more reliable, the hydrometer test, or testing under load?
Old Sep 5, 2009 | 10:34 PM
agg_bagg's Avatar
agg_bagg
that i'm not sure about. i have just always taken them to my battery shop and they always test them under load. i have never seen them do the hydrometer thing.
Old Sep 5, 2009 | 10:42 PM
mueckster's Avatar
mueckster
I have used both methods. My commercial MAC battery charger has a "built in" 200 amp load for testing. I have used a hydrometer to test the % of charge and found my battery cells to be only 50-75% charged. This lead me to discover that my alternator wasn't charging sufficiently and would also discharge the batteries when the engine was off.
Old Sep 6, 2009 | 02:07 AM
Nick 99's Avatar
Nick 99
A hydrometer is used to measure the state of charge of the cell being tested. It does that by measuring the specific gravity of the cell. A good hydrometer will have a chart for temperature correction. A load testor will tell you the heath of a battery provided the battery is fully charged first. A simple test at home would be to measure the lowest voltage (valley voltage) at the starter terminals when cranking the engine. A valley voltage of 10.5VDC or less would indicate that the batteries were weak.
dloomis
20
Apr 18, 2013 03:41 PM
SmokeBlower
48
Sep 14, 2010 04:26 PM
tetsuo73
Jul 29, 2009 07:59 AM
Plat7.3
Sep 17, 2007 08:18 AM
92F150Flare
May 31, 2007 05:23 PM
