Engine Fan Running All The Time
Old Oct 28, 2018 | 09:11 AM
roostercrows's Avatar
roostercrows
Hey guys,
Its as simple as the title says, my fan runs all the time, from the time I start the truck until I shut it down. I assume its the clutch but I'm looking for other potential causes before just go ahead and replace it.
The oil temp is steady at 175*, and the tranny temp stays at 135*.
Could there be another cause for this?
Old Oct 28, 2018 | 09:32 AM
Walleye Hunter's Avatar
Walleye Hunter
Usually when the fan clutch fails it locks up. Try spinning it on your cold truck and see if it's frozen up.
Old Oct 28, 2018 | 12:40 PM
axmrdr's Avatar
axmrdr
I think you already figured it out.
Old Oct 28, 2018 | 12:59 PM
roostercrows
Thanks Mark, I checked and its frozen. Now is it possible that since I just had the fan off to install the Navistar water pump and maybe didn't re-install it properly? Or is it just the clutch is done?
Old Oct 28, 2018 | 01:03 PM
Walleye Hunter
I don't know if or how it could installed improperly. It's just the large nut off and then back on, isn't it?
Old Oct 28, 2018 | 01:06 PM
roostercrows
I think your right Mark, I thought I'd ask the question though.
Now is it ok to drive as is?
Old Oct 28, 2018 | 01:07 PM
Walleye Hunter
Yep, it will just be noisy and steal some of your HP. But in the winter it will prevent the engine from getting warm.
Old Oct 28, 2018 | 01:11 PM
roostercrows
Thanks Mark.
Old Oct 28, 2018 | 01:39 PM
Bill Kay's Avatar
Bill Kay
I was always told that laying a fan with a thermal clutch down flat will cause them to go bad. Probably not true because when you buy one at the parts store they don’t even consider the orientation of the box it is in. That said, did you lay it flat for an extended period of time before re-installing it?
Old Oct 28, 2018 | 02:57 PM
roostercrows
I did lay it down on the ground but only for the time it took to change out the water pump, like 3ish hours.
Old Oct 28, 2018 | 03:11 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I had my fan clutch flat/horizontal for a couple days and it is fone 4 years later. Also, think about special handling that would be needed during shipping from the retailer if this was true.
Old Oct 29, 2018 | 12:23 AM
'88 E-350's Avatar
'88 E-350
There are some clutches that can leak if laid flat, old Porsche I think it was. These clutches don't care. It could be that you damaged it somehow or maybe just a fluke that it failed right after the work.
wtroger
1983 - 2012 Ranger & B-Series
Sep 1, 2011 01:00 PM
cornking
18
Sep 23, 2010 03:13 AM
jpcjguy
Jul 7, 2010 12:03 PM
scionti 94
1978 - 1996 Big Bronco
Jun 14, 2008 11:13 PM
IceboxFX
29
Jan 19, 2008 10:47 AM
