Fan Clutch
Old Aug 30, 2011 | 04:06 PM
wtroger's Avatar
wtroger
Fan Clutch
2003 2x4 Ranger 2.3 dohc 5 speed with air 133000 miles. When the engine is cold and the air temp is 80 degrees F should the fan blade stop moving 1 min or so after start up. Mine does. it will slow to the point of barely turning. It also has a factory electric fan that runs when the AC is on and I suppose it comes on if the engine gets hot enough. I all my years of auto work I have not seen this before I would assume this means the fan clutch is bad but was just wondering if anyone has observed this before. I do not have any overheating issues.
Old Aug 30, 2011 | 10:03 PM
cj06's Avatar
cj06
it should not slow that much , any noises when you turn the fan by hand or any wobble ? hows the water pump ?
Old Sep 1, 2011 | 11:11 AM
wtroger's Avatar
wtroger
I have ordered a new Motorcraft fan clutch. I will change it as soon a I can once it gets here. And Fyi the fan on the DOHC engines are not attached to the water pump they are just on and idler pulley.
Old Sep 1, 2011 | 01:00 PM
cj06's Avatar
cj06
what was i thinking , probable was not !
peter_x
Nov 16, 2011 07:42 PM
Ritory
Nov 22, 2010 04:02 PM
scionti 94
1978 - 1996 Big Bronco
Jun 14, 2008 11:13 PM
old blue 90
Sep 25, 2007 08:33 AM
bluneon
May 17, 2006 09:59 AM
