So i have my quickfuel choke already wired up and know it works this way as it used to work perfect. However now it is not working due to not having any voltage at the choke. I am using the anti diesel solenoid wire (blue) as my 12v signal which is right next to the original wire (white with a strip) used for the choke that comes off the alternator.
i have no voltage at the blue wire used for the anti diesel solenoid. I cannt find a wiring diagram that shows the anti diesel solenoid. I have read this goes straight to the fuse block. So i have ohm checked all the fuses for continuity and they all checked out good. What else could i check for to see where i am losing current? Once the blue wire goes into the wire loom i loose it and cannot find were it goes under the dash. Thanks
If someone knows of a wiring diagram that shows this blue wire that would also be helpful. However an explanation of where this goes would also be helpful as although these wiring diagrams are relatively simple i do not have much practice reading these.
Never mind... went out to double check everything and it is a blown fuse. Must have skipped over it when i was checking all of the others. I have been having electrical issues like no other recently thats why i checked then all. Thanks anyways.
