choke wiring
Old Dec 18, 2018 | 12:01 PM
bigoldtruck's Avatar
bigoldtruck
choke wiring
Hello. Mine is a Carter AFB on a 390, 1973 F250. I don't know how much of the motor was original to this vehicle. The wires have been intensely messed with. I have been studying some posts on here related to choke wiring and I have learned that there should be one hot wire to the choke. Mine has 2. One is from a little black box on the alternator and shows 4.3 volts with the engine running. The other wire shows 13.5 volts. This being (I imagine) an aftermarket choke, it seems there should be only the one wire hooked up, and that the 13.5 one.
My plan is to unhook the stator wire and put a ground wire on that spade clip. Does this sound like a good step?
Old Dec 21, 2018 | 03:01 AM
z28tito's Avatar
z28tito
If it is indeed an aftermarket electric choke and t has 2 spade terminals, one should be for ground, and the other should hooked up to a switched 12V source.
Old Dec 21, 2018 | 11:07 AM
bigoldtruck
z28, yup, after my post I did as you suggest. I think the choke is working normally for the first time.
dgoodsy
Mar 20, 2019 09:05 AM
ktm4012
Oct 12, 2016 10:48 AM
JGolden
Oct 26, 2011 12:28 AM
big hoss 29
Jan 20, 2008 09:02 AM
X-1
Mar 29, 2004 12:01 AM
