Cold no start
Old 10-26-2018, 10:06 AM
429poweredf350's Avatar
429poweredf350
429poweredf350 is offline
Cold no start
Just picked up a 2000 Ex with 7.3 330K miles but runs great and well maintained. Drove to NY last week where temps were a little cooler and didn't want to start. Turns over but no fire.. Will start after several attempts. Any idea where to start looking?
Thanks,
Jerry
Old 10-26-2018, 10:15 AM
PrescottIce's Avatar
PrescottIce
PrescottIce is offline
Old 10-26-2018, 10:43 AM
429poweredf350
Much appreciated
Old 10-26-2018, 11:11 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Numba one suspect glow plug system and it's something you'll want to check this time of year anyway, it won't start with them.
Old 10-26-2018, 11:17 AM
Sous's Avatar
Sous
Sous is offline
Received 4,473 Likes on 2,857 Posts
The glow plugs can be checked via ohm with a 2.0 or less reading as good from the harness on the outside of the valve cover. No need to remove the valve cover to check them. Simply use a multimeter and ground the black lead, then test each of the 4 outer pins (slightly larger than the other pins) in the valve cover connector.
GP pins on the harness...
location of connector with pins you should be testing...
The GPR (Glow Plug Relay) can also be a cause of a no start condition because if the GPR has failed, none of the GP's will work as designed.
Old 10-26-2018, 11:25 AM
Walleye Hunter
Excursions have glow plug control modules. Is it possible to diagnose them with ForScan?
Old 10-26-2018, 11:35 AM
Sous's Avatar
Sous
Sous is offline
Dangit, missed the Excursion detail. Although, some Ex's have the GPR, but most have the GPCM.
I don't think you can diagnose the GP's with Forscan, but the test should be the same for the GP's whether you have the GPCM or GPR.
Is that enough acronyms or am I still short?
timeld
1999 to 2016 Super Duty
11-11-2014 01:14 PM
Km1210
11-17-2011 10:35 AM
ozzy460
12-31-2010 10:23 AM
JumpinJoe
04-17-2009 06:22 PM
Quick Reply: Cold no start
