And now for something completely different.
Old Oct 26, 2018 | 01:25 AM
Signgonzo's Avatar
Signgonzo
OK, I may be way out in left field here but I want to know what you guys think. I have a 1979 F250 with the 300 six. Funny thing, those are tough engines but they just won't run without oil. Anyway I'm wondering if I could affordably convert this motor to a stationary motor in a genset after I rebuild it. I know about the real 300 six industrial motors on the market and I realize they are modified quite a bit, but I can't help but think a well built stock motor could do the job. I'm not talking about a constant run application here. I live off the grid and I use solar for my daily electrical needs, but there are times I need more juice than my battery bank can supply i.e. welding and such. That is when a skookum generator would be nice. Thanks for any ideas you might want to share.
Old Oct 26, 2018 | 10:34 AM
pmuller's Avatar
pmuller
What is a skookum generator?
Old Oct 26, 2018 | 12:00 PM
85e150's Avatar
85e150
That would be a good strong well made generator that would fire and run any time any condition. It's a northwest thing, coming from "Chinook Jargon".
https://en.wikipedia.org/wiki/Skookum
For the OP, sure that motor will work for that. Electronic ignition will be your friend. Stabil or other fine brand of fuel stabilizer, and weather proofing like you were in Antarctica. And a test fire 3 or 4 times per year.
Serving suggestion.
Old Oct 26, 2018 | 12:17 PM
pmuller's Avatar
pmuller
Thanks for the Skookum definition. I lived in Washington state for 25 years and didn't know. I got to learn at least one new thing today.
The one challenge will be creating throttle control for either rpm or load.
If you run a DC generator to supply current to the battery bank then the engine can be governed so that it only supplies enough current to cover the load by varying the rpm rather than a constant rpm.
The engine will idle at no load and the rpm will increase only as the load increases.
Better fuel efficiency along with longevity.
Old Oct 26, 2018 | 02:04 PM
85e150's Avatar
85e150
Lots of hits for engine speed control, but OP will be doing a lot of reading to sort out a system that will work.
This outfit sells the 300 industrial, reman'd version. And the governor to go with it. Get your checkbook out....
https://www.foleyengines.com/tech-ti...trial-engines/
Old Oct 26, 2018 | 02:47 PM
Signgonzo's Avatar
Signgonzo
Thanks for the speedy response. I lived in Alaska for 17 years and saw many 300 sixes, industrial and otherwise. They were used a lot in snowcats and weasels (tracked vehicles) but not a lot of stationary applications. Just gotta figure out what RPM makes 60hz and how to govern that. I know Foley has governors and I hear that are pretty spendy. I'm retired and would like to do this without going into hock. I just wanted to know if you guys think an engine made for vehicular use will work as a stationary. Looks like I need to research governors. I always liked Hickel
Old Oct 26, 2018 | 08:21 PM
pmuller's Avatar
pmuller
AFAIK a 4 pole stationary generator operates at 1800 rpm to produce a 60hz output.
The 300 six with a stock cam also produces peak torque at 1800 rpm.
The 300 industrial engines were set up to run many hours before rebuilds.
Some had steel crankshafts. Most had hardened exhaust valve seats especially if the engine was run on a gas instead of liquid gasoline.
It doesn't sound like you will be running your 300 for long periods of time.
My suggestion is to rebuild the engine with hypereutectic pistons and not worry about upgrades anywhere else.
If the crank is damaged beyond repair, you can get a new cast steel industrial crank from OXX for $95 plus shipping.
Old Oct 26, 2018 | 11:14 PM
Signgonzo's Avatar
Signgonzo
Thanks pmuller
That is some great info! I really appreciate it.
Old Oct 27, 2018 | 08:46 AM
john jamieson's Avatar
john jamieson
I seem to recall that at one place I worked, we had a Miller gas powered welder that we also used as a generator. That might also fit the bill
Old Oct 27, 2018 | 05:57 PM
The Frenchtown Flyer's Avatar
YES
The HD engines were intended to be used for continuous operation and had to be built for long intervals between service.
For your application where you will be using it occasionally and not necessarily at the rated output it will be a "walk in the park" for a vehicle engine.
Old Oct 27, 2018 | 07:13 PM
Signgonzo's Avatar
Signgonzo
That seems to be the popular consensus. Now I will just need to rebuild the motor. My son ran it out of oil so I don't yet know the horrors I will find in the autopsy. Should be fun tho. This forum is a really valuable resource, but I am preaching to the choir. Now, if you will all open your hymnals to page 62.....
Old Oct 28, 2018 | 12:38 PM
weswes01's Avatar
weswes01
I too live off grid. It’s amazing how much a slow cooker draws. Every time I hear that dam Koehler generator kick on, I wish it was a 300. It’s like listening to elementary school kicks play the recorder or Nails on a chalk board.
1999-F150
1997 - 2003 F150
Nov 29, 2018 06:54 PM
dylansf23
May 25, 2015 09:49 PM
eco
Sep 16, 2006 05:27 PM
asauppee
Nov 28, 2004 04:47 PM
wrenchturner
25
Sep 20, 2004 01:08 PM
