Turbo Options/Possabilities
Old Oct 24, 2018 | 08:18 PM
Sethro84's Avatar
Sethro84
Exclamation Turbo Options/Possabilities
So, I may be barking up a tired tree, but are there any turbo options for the inline 300's? Kits? Scab one together?
Point me in the right direction fellas!
Old Oct 24, 2018 | 08:28 PM
85e150's Avatar
85e150
DIY. This thread will have you up late. AFAIK, and can remember, this is the only guy with a working turbo 300 setup. There was an epic turbo 300 thread that ended with the sale of the vehicle. I don't know if he ever took off on boosted power. Enjoy:
https://www.ford-trucks.com/forums/1...6-sleeper.html
pmuller's Avatar
pmuller
What year 300 engine do you want to turbo?
Old Oct 25, 2018 | 02:20 PM
Sethro84's Avatar
Sethro84
95 300 EFI no Mass Flow
Old Oct 25, 2018 | 02:45 PM
Harte3's Avatar
Harte3
https://fordsix.com/viewforum.php?f=22
Try that Forum.
Old Oct 25, 2018 | 08:33 PM
pmuller's Avatar
pmuller
The easiest direction would be to replace the stock ECM with a Megasquirt 2 box that plugs directly into the stock wire harness connector and do your own programming. There is plenty of help.
Another possibility is to use an Offenhauser "C" manifold with a self learning Holley Sniper EFI as a blow-thru set-up.
The next question is what type of power are lookin for?
Low rpm to mid range torque or higher rpm horsepower?
Old Oct 29, 2018 | 08:16 AM
fljab's Avatar
fljab
And he's got a new wrinkle with adding a Kenne Bell blower that is fed by the turbo!
1972RedNeck
Jul 21, 2012 01:39 PM
tjthegreat
Feb 20, 2008 11:09 PM
TrimmellFord
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
May 7, 2004 10:40 AM
grenadier
Oct 16, 2002 05:18 PM
