‘52 Steering box
Old Oct 25, 2018 | 04:14 PM
Mrln45's Avatar
Mrln45
‘52 Steering box
Recently received a gasket set for my steering box. But there are two round “felt” pieces. What are they for; where do they go?
Old Oct 25, 2018 | 08:50 PM
3twinridges's Avatar
3twinridges
The felt donut slides down the steering shaft to seal the top of the box. It just sits on top. Not sure about the circle, maybe it’s just the cutout of the donut?
JB
Old Oct 25, 2018 | 09:05 PM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
I agree with JB about the round piece just being the unneeded cutout of the donut.
And I recently re-assembled the box on my '49 and used the gasket shims to dial in as little play as possible. It was definitely trial and error!
If you haven't done a box like this yet, start out with two shims, adjust the lash, assemble and test. Use a little grease on the gears during testing, no liquid lube yet.
Dry-fit the steering wheel on the shaft and turn it lock-to-lock several times to see the amount of play. Add a shim gasket, repeat the test. Remove a shim if needed.
I spent quite a bit of time last winter in my cellar near the wood pellet stove to get the least amount of play combined with no apparent binding. In the end I narrowed it down to only 1" of play at the steering wheel. Based on feedback I got and info on threads here, that is about as good as it gets. I have test driven my '49 truck since then and the 1" of wheel play is barely noticeable compared to a steering box on my '51 that didn't get this amount of attention.
Hope this helps, Tom
Mrln45's Avatar
Mrln45
[QUOTE=3twinridges;18270041]
JB
Does it need to be saturated with oil or something? What purpose does it serve, just sitting on top?
Old Oct 25, 2018 | 09:08 PM
Mrln45's Avatar
Mrln45
[QUOTE=pineconeford;18270082]I agree with JB about the round piece just being the unneeded cutout of the donut.
Thank you!
pineconeford
I think it will prevent dirt & road grime from sneaking down into the box and causing wear. I put marvel mystery oil on mine. Tom
Old Oct 25, 2018 | 09:10 PM
3twinridges
I am guessing to keep debri from entering the box from the steering tube and to keep any sloshing gear oil from coming out. I saturated mine with some oil.
JB
Old Oct 25, 2018 | 09:34 PM
Mrln45's Avatar
Mrln45
Thanks for the information and advice. What do y’all think about using “John Deere Corn Head” grease inside the box? Or just stick with the heavy gear oil?
Old Oct 26, 2018 | 12:42 AM
F-ONE's Avatar
F-ONE
I know grease is an old trick that many recommend, especially for a leaky box but....
In an axle the grease heats up to a point and lubes the bearings. Also the bearings are packed.
In the steering gear there's not the heat or movement like in an axle. Because of this, the gears may simply push the grease out of the way and be somewhat dry.
For a leaky box that looses oil...grease is better than nothing.
Old Oct 26, 2018 | 09:31 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Corn head grease is very different from chassis grease. There are none of the concerns above. Watch some of the many YouTube videos showing its performance.
Old Oct 26, 2018 | 09:33 PM
52 Merc's Avatar
52 Merc
Is this one you'd recommend watching?
It sounds like you think corn head grease is a good thing in a steering box?
Old Oct 27, 2018 | 10:31 PM
Mrln45's Avatar
Mrln45
Horn
And as for the horn/steering wheel..When I removed the steering wheel the nut was on top of the metal cup. But in the diagram it shows the cup on top of the nut. Did the previous owner have it assembled backwards?
Old Oct 27, 2018 | 10:37 PM
3twinridges
Cup is held in by the nut.
I just rebuilt a box tonight, the clear coat is drying now. I sealed the threads on all the bolts and used “the right stuff” under the star washer. I am going to gamble and try 140 gear oil in it! I can’t resist LOL 😬
JB
1972fordhighboy2
Mar 24, 2016 07:54 AM
agryphon
1983 - 2012 Ranger & B-Series
Sep 28, 2006 10:11 PM
rabidranger
Mar 3, 2004 08:52 PM
ford351c
May 19, 2003 10:14 PM
