Door locks jammed locked
Old Oct 24, 2018 | 07:21 AM
brooksa44's Avatar
brooksa44
Here is one for the group!,
Went out to go to work and hit unlock on my fob and all I hear is clicking from passenger door? All locks would not unlock from driver door, even with the key? Finally got driver door open using the key and forcing it but will not stay unlocked? I had to crawl out passenger side when I got to work, wouldn't even open using handle from inside? Passenger switch will unlock passenger door and that's all? Switch? Actuator? wire short? Anybody had issue like this?
Old Oct 24, 2018 | 09:28 AM
thor363's Avatar
thor363
Unplug the master switch set in the drivers door and unlock them manually. Plug it back in and see if it locks them all when plugged in.
Old Oct 24, 2018 | 09:32 AM
brooksa44's Avatar
brooksa44
Yes, I have tried this and still won't unlock manually, none of them will? lol
Old Oct 24, 2018 | 10:48 AM
thor363's Avatar
thor363
When I say manually, I mean pull up on each unlock and not use any switches. If they won't come up, the mechanisms are each probably seized.
Old Oct 24, 2018 | 10:55 AM
brooksa44's Avatar
brooksa44
Well took switch from passenger door and plugged into drivers side and everything worked normal except drivers door, still locked and will not open,
Old Oct 29, 2018 | 09:28 AM
brooksa44's Avatar
brooksa44
Update,
I believe the drivers side actuators are shot, only problem now is the driver rear door will not open, seems the lock is jammed locked, lock will not pull up and door will not open from inside or out. I pulled the panel and the mech seems to be in working order just cant figure out what is going? Anyone have issue like this?
Ryno1
Aug 19, 2021 12:25 PM
Amr091078
Oct 17, 2018 05:27 PM
R&RFord
Apr 1, 2018 09:18 AM
EMD_DRIVER
Jan 2, 2012 07:32 PM
Trevor1
Jan 4, 2008 04:04 AM
