Problem with Driver Side Door Lock
Old Mar 31, 2018 | 09:39 AM
R&RFord's Avatar
R&RFord
Hey Folks,
Got a weird issue with a door lock. Driver side door lock switch will no longer unlock either door when the door is closed. Works when door is open. Will lock doors open or closed. Locks do not unlock from key fob either. Lock but no unlock. Didn't try the fob with the door open. The passenger side switch works normally.
I presume the fob/security module talks to the switch on the driver side which is why the fob operation is affected.
I don't get why it would work with the door open but not when closed. Wire getting pinched? Problem with the security module?
Question - How does the security module know when a door is closed or open?
Your thoughts are appreciated.
Old Apr 1, 2018 | 09:18 AM
R&RFord's Avatar
R&RFord
Problem solved. Looks like when the aftermarket security system was grafted over the factory system they spliced into the door locks circuit in the wire loom boot between the door and cab and one of the splices came apart. Why they choose that spot I'll never know but it is fixed now.
Happy Easter Folks.
Ryno1
Aug 19, 2021 12:25 PM
fcctobe1
Dec 21, 2012 03:50 PM
sethjamto
Jul 21, 2011 11:14 AM
jjs2032
Apr 22, 2008 08:27 AM
busdriver47
Aug 1, 2006 05:28 AM
