Console
Old Oct 23, 2018 | 07:56 AM
Brian Graham's Avatar
Brian Graham
Console
has anyone changed out the jump seat/console with the flow through style? I know the rear vents won’t work and I’m ok with that. Can’t seem to find a part number for it or do I have to buy each piece individually? Thanks in advance
Brian
Old Oct 23, 2018 | 08:05 AM
dksmith17's Avatar
dksmith17
https://www.ford-trucks.com/forums/1...le-swap-2.html
Old Oct 23, 2018 | 08:11 AM
Brian Graham
Thanks!!! Couldn’t figure out how to search this forum. I appreciate the link
Old Oct 24, 2018 | 12:23 AM
brandontolentino's Avatar
brandontolentino
There’s a video on YouTube as well that is useful. You can get the right parts to make the rear vents work too, just requires some cutting to open up the port for the rear output in the dash.
Old Oct 25, 2018 | 07:38 PM
Genenj89's Avatar
Genenj89
I just did a swap in my 18 and the vents will work. I ordered the two extension vents that go from inside the dash to under the console. You have to trim out two spots in the ducting under the dash, the one extension duct slips right onto that one, and you mount it with two mounting bolts. The other piece slips on underneath that one and comes out on the floor and meets up with the vent tube inside the console. I used a console out of a lariat. I got everything functioning like it would factory, only thing I deleted was 110 plug, I have no inverter and don’t care to install one. Look it up on YouTube there’s a few videos.
srkr
Dec 27, 2020 05:48 AM
scott.sanders
May 4, 2018 07:21 PM
F350-6
Jul 15, 2016 09:45 PM
036.0stroke
Jul 30, 2012 08:54 AM
KDN739
Mar 9, 2011 10:48 AM
