Battery question?
Old Oct 23, 2018 | 01:54 AM
hhowell1990's Avatar
hhowell1990
Battery question?
My trucks been sitting at about 11.9v or so for the past few months and I’ve noticed over the past few weeks it’s been slow to start on Monday mornings after sitting over thr weekend. My batteries are a little over 3 years old and I’m thinking it’s about time to replace them, does anybody know if a group 31 battery will fit in the factory trays?
Old Oct 23, 2018 | 11:21 AM
69cj's Avatar
69cj
Don't know about the group 31's but that low voltage is like playing Russian Roulette with you FICM and injectors.
Old Oct 23, 2018 | 02:40 PM
hhowell1990
thats just the voltage when it’s sitting there off. Once I start it and the glow plugs shut off it goes up to 13.5-14 running
Old Oct 24, 2018 | 11:16 AM
69cj's Avatar
69cj
A fully charged static battery will read 12.6 volts. You're too low. FICM should never drop below 47 volts.
Old Oct 24, 2018 | 11:58 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
^^^ this. You're stressing the alternator trying to charge undercharged/damaged batteries. Float voltage of 11.9V is too low like Mike said.
Bare minimum it's time to pull the batteries, charge them separately, strip the surface change and load test. $5 they both fail.
Old Oct 24, 2018 | 01:43 PM
69cj's Avatar
69cj
Is that 5 per battery?
Old Oct 24, 2018 | 02:00 PM
hhowell1990
I realized I’m causing undue stress on my alternator and whole electrical system having low batteries, hence why im in the market to have them replaced, my original question hasn’t been answered yet tho, will a group 31 battery fit in the stock trays?
Old Oct 24, 2018 | 02:07 PM
seville009's Avatar
seville009
Just measure the tray.
My guess is that they won’t fit because the stock group 65 battery seems to just fit in my truck.
Old Oct 24, 2018 | 03:13 PM
69cj's Avatar
69cj
He also has to match or exceed the CCA's.
Old Oct 24, 2018 | 04:08 PM
diesel_dan's Avatar
diesel_dan
a 31 is longer and taller than a 65. I'd probably be more worried on the height as you likely can get it to sit on top of the tray edges. Here's the measurements, take a tape measure out and check...
BCI Grp 65: 12.0625"L x 7.5"W x 7.5625"H
BCI Grp 31: 12.9"L x 6.75"W x 9.27"H
I just put some Group 31s starting batts from Napa in our motor home, they were 950CCA...
Scott
Old Oct 24, 2018 | 04:38 PM
hhowell1990
I just started the truck and ran a data log on FORScan looking at FCIM voltage and it sat at 48.5, it did dip down to 48 a few times when I blipped the throttle bot only while the glow plugs were still on. Once they were off I hit the throttle a few more times and it sat at 48.5 the whole time. Should the half volt drops be concerning or no since it was only when the glow plugs were on and the FCIM was only seeing ~11.8 from the charging system at the time?
Old Oct 24, 2018 | 05:50 PM
69cj's Avatar
69cj
FICM appears to still be good. Don’t push your luck with those battery’s.
Firefighter 1406
26
Apr 13, 2019 07:52 AM
mblanken881
Jan 20, 2012 07:56 PM
FICMrepair.com
Nov 6, 2011 06:21 PM
caseydudem
Dec 27, 2010 06:32 AM
peglegger
13
May 9, 2010 11:32 PM
