Battery voltage
Old May 8, 2010 | 08:21 PM
peglegger's Avatar
peglegger
Battery voltage
Why is it that when I stick a volt meter of the batteries it reads 24+ volts? Are they wired wrong?
Old May 8, 2010 | 08:35 PM
af4ms's Avatar
af4ms
Wow, where are you doing your testing? The batteries should be in parallel and read 12.4ish when not ving charged. If under a charge and the glow plugs are not activated then they should read in the 14's.
Old May 8, 2010 | 08:52 PM
peglegger's Avatar
peglegger
I'm testing right off of the battery terminals.
Old May 8, 2010 | 09:00 PM
af4ms's Avatar
af4ms
It sounds like the batteries are hooked in series and not parallel. At the +- terminals of one of the batteries it should read 12 ish. I would think you would be havings some terrible problems.
Old May 8, 2010 | 09:06 PM
af4ms's Avatar
af4ms
One thing to look for is to see where the - (negative) battery cable goes on each battery. This will give you an idea how the battery cables are hooked up.
Old May 8, 2010 | 09:07 PM
af4ms's Avatar
af4ms
From the negative terminals of each battery, where does each cable go to?
Old May 9, 2010 | 01:05 AM
Visseroth's Avatar
Visseroth
Driver's side battery:
Negative to Body or engine
Positive to Positive of Passenger's side battery
Passenger's side battery:
Negative to body or engive
Positive to starter or distribution block
I am doing this from memory and that is why I say "or" but as they said, if you have 24v then you are WAY over volting your system and you are taking a chance on frying equipment including your PCM, IDM, stereo, anything in the rig as most can't handle much over 18v
Batteries when the vehicle is off should be about 12.1 to 13.9. 13.9 is after a fresh charge, 12.1 is after sitting for a few hours or more, 12.5 is preferred.
13.2 to 14.2 is a normal running range. 13.8 is the preferred voltage (Engine running).
If you are at 24v then your positive on battery A is tied to the negative on battery B and your negative on battery A is tied to the body of the vehicle and B is tied to the starter.
(WARNING)Fix your problem before you burn something up or burn your truck down.
Old May 9, 2010 | 01:08 AM
Visseroth's Avatar
Visseroth
Do you need to know the specific locations? If so I'll get you some pictures.
Old May 9, 2010 | 12:04 PM
af4ms's Avatar
af4ms
No no, I was aking the original poster to look at his setup. He obviously had his wired in series to get 24 volts. I would say there are some other things not working if there is not a system in place to protect the electronics.
Yes, your post is right. Positive to positive and negative to negative (or ground).
Old May 9, 2010 | 12:10 PM
clintbonnie's Avatar
clintbonnie
Remove the positive cable from one battery and test your voltage off the battery terminals.. to check your tester..
Or.. check the voltage on another vehicle if you can to double check the voltage tester...
Old May 9, 2010 | 06:42 PM
SpringerPop's Avatar
SpringerPop
That would be my first guess, too.
His meter is AFU.
Pop
Old May 9, 2010 | 08:17 PM
c125bob's Avatar
c125bob
Surely it's his meter. Otherwise he wouldn't be able to see it to read it for the smoke !!
Old May 9, 2010 | 10:29 PM
af4ms's Avatar
af4ms
I just think it is odd that his meter would be off by a multiplier of 2 (unless he was reading with a oscilloscope and had a X2 probe on the unit ). You would think if the meter was an issue then it would probably not be reading an exact double of what it should be. Considering it would be easy (having one of the batteries turned around backwards allowing the terminals to be opposite of the cable sides) to hook them up in series and get 24 volts. He has not been back since his original posts. Hope everything is ok.
Old May 9, 2010 | 11:32 PM
SpringerPop
That scope probe you describe would be reading six volts. Scope probes are dividers, not multipliers, not to mention that a 2X probe would be kinda' unusual in itself. 10X would be far more common, with 100X being somewhat less so.
Considering that if he had one of the batteries turned around, he would have, in essence, a 24 volt battery with a DEAD SHORT, he wouldn't have 24 volts, he would have smoke, molten lead, and possibly an explosion. That WOULD NOT be "easy".
If you turn one of these batteries around, you will NOT have a 24 volt battery, you will have a huge short, and you'll INSTANTLY know it! POW!
This is not what his mis-reading is caused by.
Pop
beckman
19
Mar 13, 2022 06:54 AM
tom1940
Sep 17, 2014 08:00 PM
jameszeesmith
Jul 1, 2011 07:11 PM
Wagion
Aug 28, 2009 10:29 PM
Alphy's
May 4, 2004 07:35 PM
