Transmission issue
Old Oct 25, 2018 | 09:48 AM
Sparks123's Avatar
Sparks123
Just got a call from the dealership. They say the transmission cooler lines were cracked and leaking. Waiting on new ones which are due tomorrow to see if that fixes the transmission issue. They have completed the door handle recall and are going to replace both the batteries for the acid leak
Old Oct 25, 2018 | 11:08 AM
BowtieConvert's Avatar
BowtieConvert
Glad you caught before it caused bigger problems. Hopefully there isn't any damage to the transmission.
Old Oct 25, 2018 | 12:08 PM
Sparks123's Avatar
Sparks123
Yes so do I 😁
Old Oct 29, 2018 | 07:15 PM
Sparks123's Avatar
Sparks123
Got it back today. They say the transmission coolant lines were cracked and leaking fluid out. Fluid level was 4 quarts low and transmission was slipping. They replaced the coolant lines. Found transmission was delayed forward (not sure what they meant with that). They removed the unit and found the forward clutch scorched and forward slip. They cleaned the forward drum, replaced forward steels and clutches and reinstalled the unit. Flushed the converter and coolant lines. Reset the KAM and refilled the transmission. Issue resolved. They also replaced both batteries that was leaking acid and did the door handle recall. Thus far it seems fine. In town the trans temp stayed at 198 to 199. Shifted fine.
Beau109
May 25, 2015 04:15 AM
fe8u
Jun 30, 2013 08:58 AM
mac1469
1997 - 2003 F150
Oct 28, 2010 12:17 AM
bigdog55
Feb 3, 2007 02:44 AM
fordlogan
Oct 12, 2006 07:24 PM
