Ford "Sync" software and design complaints
1 - I recently towed a trailer. Now my display goes to "trailer status" no matter what I set it to, regardless of whether a trailer is connected or not.
2 - I inadvertently left one of the overhead map lights on. Happened to notice it from inside the house, went outside to turn it off. It is not possible to turn off this map light unless you get in the truck, close the doors, wait for the interior lights to go out, THEN turn off the map light. Fubar. The switch should turn the light off regardless.
3 - Dash buttons: If you turn on the engine braking, you cannot turn it off until you shutdown the engine and restart. The button right next to the engine braking is the traction control, which can be turned on and then back off using the switch without restarting. Why is the behavior of switches not the same?
4 - One can drive down the road and adjust the drivers seat in all manner of ways, For heavens sake you can even adjust the pedal positions while driving, which seems surprising. But to memorize or select a memorized seating position, the vehicle must be stopped! Totally irrational.
5 - I hate dingers. I truly DESPISE dingers. I want to be able to turn off all my damned wretched infernal dingers. This truck dings at me for everything, parking brake, seat belt, lights I WANT IT TO STOP DINGING. Its my bleeping truck, Ford, why can't I turn this irritating crap off!?! I dont want a $60K vehicle pissin me off! Sorry...did I mention I hate dingers?
6 - Every time I put the truck in park with the engine running, get out and shut the door, the horn honks twice! Why does the horn honk? What is it telling me? I know I left it running, I *meant* to! I want to start the truck on a cold morning, and go back inside and get my coffee and lunch, and the nice super quiet truck that I paid so much for HONKS THE BLOODY HORN and wakes people up for absolutely no reason. Totally illogical.
7 - The hood interior lights go out after a period of time. I guess the pinheads at Ford believe every underhood fix can be accomplished within their preordained hood light timeout. Stupid.
8 - I wont go into all the aggravation of the audio source being changed to AM static every time I shutdown and restart, that is addressed elsewhere by lots of others.
9 - The trailer controls wont let the driver change the brake gain setting unless the vehicle is parked. Wow, that's not enough gain for this heavily loaded trailer, I gotta stop to change it? Come on, Ford software weenies, have you ever towed a trailer? I want a different setting on brake gain at interstate speeds versus stop-and-go traffic. No can do without parking.
10 - Every time I unlock the truck, it lights up every external light on the thing. Very irritating when unwanted. I guess the Ford designers have never used their truck for camping or hunting or some activity where they might want to remain just a wee bit less obvious and irritating to others.
11 - The button to open the sunroof opens the shade as well. The button to close the sunroof does NOT close the shade as well.
12 - The behavior of these buttons (short press versus press and hold) is totally inconsistent from one button to the next. Some one touch does one thing while on another it causes different behavior. This behavior should be consistent across all switches. See also #3 above.
13 - With all this automation, why cant Ford give me a single button that closes all the windows, sunroof and back slider? Too much to ask that they think about utility and usefulness? Do any of the Ford designers and coders even live with their product?
Got any to add, please do.
If you know of a way for me to correct any of the ones I have complained about, please enlighten me. I am probably overlooking something obvious.
I wish someone would hack the OS on this thing so I can adjust all the stuff that Ford prevents me from adjusting.
However, some of your complaints are mine as well. I will be taking delivery of my 2019 Lariat Ultimate next week and did quite a bit of reading
while waiting for it to be built. I found a thread, and if i knew how to link to it i would as there was a TON of good info there, on using a OBDLink MX Bluetooth: Professional Grade OBD-II Automotive Scan Tool to change a lot of those default setting......some, not all.
V/R
K
Many of the annoyances you mentioned are addressed with the options in Forscan. I'll be honest I would have taken the truck back to the dealership if I wasn't able to make the changes at home so I totally understand your frustrations.
Of all the videos I’ve watched demonstrating Ford’s “superior” tow features, some of them at press demo days, not a single mention has been made of this strange configuration. Journalists talk about how silly some of the guidances features are, especially for seasoned towers, but have never mentioned it missing a critical feature like on-the-fly gain control. First time I’m ever reading about it here.
Is this really true??
HJ this one worked perfectly for me using a PC laptop. My only issue was the switch was either wired or labeled backwards. Took me a few attempts with the Forscan guys (who are incredibly awesome btw) to figure out the mistake. So the solution for me was to have the switch flipped opposite of the instructions and prompts. Lol. Likely I would get the only one wired wrong or labeled wrong in the world but that was my only issue.
I'm right there with you being on a steep learning curve as well so it isn't just you.
Still looking for a good wireless scanner that I can leave in and use to read gauges, etc on my phone or iPad on trips.
2. Pretty sure you can still just hit the light switch again, it'll go off with the other lights as it's powered because you have the door open.
3. I just got my 2019 yesterday and haven't used the exhaust brake yet but my 2017 was not like this, it could be changed on the fly.
4. I kinda understand why they did this but I agree, it's stupid.
5. You'd have to use Forscan for those items that can't be turned off in the vehicle settings.
6. Do you have push button start? It'll honk to tell you your truck is running and the key isn't inside the vehicle. Maybe, if equipped, remote start the truck from inside the house?
7. Never realized this.
8. I read about people having this issue after updating their Sync software, however, I do not have this issue. Maybe the dealer can do an update?
9. I don't believe this was a thing on my 2017, I'm pretty sure I could change it on the fly. Haven't towed with the 2019 yet.
10. Forscan if not capable to disable in vehicle settings.
11. This is how most sunroof work. I would imagine it's to ensure the cover doesn't close without the sunroof closing.
12. I'm not familiar enough with this one.
13. This would be nice.
I figured as much. I have made several attempts to unselect a trailer, and as yet have been unsuccessful. There's only one trailer entered, and as far as I can discern, there is no "none" option., And what kind of stupidity would have designed it to insist that the trailer is connected, despite the fact that the system knows it is NOT connected? I would expect it to be screaming at me that the connection has gone away! This would be desirable/useful behavior to me, hey fool, you have pulled the trailer connection accidentially! But alas, apparently not?
