Ford "Sync" software and design complaints
#76
Another design complaint to add to my list: Having to RE-select "tow/haul" after every restart even when there is a trailer connected. This is dumb, and probably will contribute to some fried trannys and maybe a engine or two. Tow/Haul should stay selected as long as the trailer that was connected when tow/haul was selected remains connected.
#77
OK, thanks, but Im not sure I believe that. Tow/haul changes the lockup RPM, does it not? Then chances are it will affect life and temp of the torque converter. But your point is well made....next time I'm towing heavy, I will attempt to watch the trans temp with and without tow/haul selected and see if I can discern any difference.
#78
https://www.ford-trucks.com/forums/1...l#post16842406
Danimal1481
05-17-2009 09:07 AM
