390 intake manifold
Old Oct 17, 2018 | 08:05 PM
mr.badwrench's Avatar
mr.badwrench
390 intake manifold
Picked up a 4bbl intake manifold that is supposed to be for a 390. not sure what it came off of. it looks similar to the 2bbl I have on my engine now but there are lot of differences. not sure where I can look up casting #s and if it will fit properly. any help is greatly appreciated.
Old Oct 17, 2018 | 09:22 PM
Christmas's Avatar
Christmas
Ford FE manifolds will fit all Ford FE motors. Couple of cool things this one has are 4V, a breather port in the rear you can hook up to a air cleaner and a oil filler that lets you run solid valve covers. The only drawback is that it weighs 100lbs. Only my opinion.
Old Oct 18, 2018 | 12:49 AM
TheMonson's Avatar
TheMonson
I used a cherry picker and a lift plate to remove/reinstall my OE manifold. Wasn't too bad doing it that way, just needed extra help to operate the picker when reinstalling.
Old Oct 18, 2018 | 01:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
This is a 1958/64 FE manifold from a car, due to the oil fill tube. Specifically it's from a 1964 Thunderbird (C4SE) 390.
All 1958/64 FE engines have a oil fill tube, rounded valve covers without holes for smog valve/oil cap.
These blocks have a different bolt pattern on the block where the rubber insulators bolt on than 1965/76 FE engines.
Casting date code 4D15: Cast April (D) 15, 1964 (4).
Old Oct 19, 2018 | 01:35 AM
Christmas's Avatar
Christmas
I have to ask the "Rubber Insulators" are?
Old Oct 19, 2018 | 02:51 AM
NumberDummy
The R/L front rubber insulators (aka motor mounts) bolt to the block then to the engine supports.
See 6038 in lower pic:
Old Oct 19, 2018 | 07:20 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Your picture didn't post Bill until I wrote this reply. Weird. Now I can't delete my post, so there's this explanation on why I wrote it.
Old Oct 19, 2018 | 06:00 PM
mr.badwrench
thanks for the info, im glad it will fit. gonna shop around for headers and possibly a mild cam.
RamblinMan1963
Oct 28, 2017 11:21 AM
money pit 69
Mar 24, 2014 02:09 PM
dohc_chump
Ford Truck Parts for Sale
Jan 9, 2011 05:04 PM
76 crew
Aug 29, 2007 06:52 AM
WC76TX
May 15, 2002 12:16 AM
