BAD PCM?
Old Oct 15, 2018 | 09:19 AM
Bombguy2's Avatar
Bombguy2
BAD PCM?
02 F250 w/ 7.3 4x4 automatic trans 167k
Trying to chase down a new problem.
Truck idles for about 5 minutes then dies. Driving down the road it has started to erratically shift between 3-4th gears. I ran FORSCAN and found the following codes.
p0476,c1284,p0284,p1536,p0220,p1780,p0565,66,67,68 and 69,p0571,p0703.
Can the PCM be going out and all these coded are just a by-product of different circuits not being able to talk to each other?
Forscan says my trucks PCMs part number is 2C3FDE but my units actually says it is 2c3f-12A650-DE.
I would hate to buy a new one if this one can either be reset or reprogrammed.
Thanks-Bombguy
Old Oct 15, 2018 | 09:46 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Your reasoning doesn’t make a sense to me, I think you just have a cruise control issue as well as a back pressure issue like a clogged tube to the sensor. Fix the codes and your running issue and pcm concern should be resolved.
but if you do need pcm work done there is only one place I would go.
https://www.dieseltechchatt.com/
Old Oct 15, 2018 | 10:08 AM
Bombguy2's Avatar
Bombguy2
Thanks for the reply. I only came up with the idea of the PCM due to an exchange I had with a tech on fixya.com
I did see a code for Exhaust back pressure so I will start there by cleaning out the tube and replacing the sensor.
thanks-Bombguy
Old Oct 15, 2018 | 10:51 AM
pirate4x4_camo
Maybe I am just being to specific but the “diffrent circuits” do not talk to each other. The pcm has inputs and outputs and all the circuits talk to the PCM not each other.
if the pcm was not communicating with a circuit you would have PCM codes or a open/short circuit code.
Old Oct 15, 2018 | 11:16 AM
Bombguy2's Avatar
Bombguy2
good to know...thanks
cobra1379
28
Apr 15, 2017 11:12 PM
luny1
Sep 16, 2011 12:49 PM
ScaldedDog
Aug 21, 2011 03:32 PM
ReserectedSD
Nov 16, 2009 09:47 AM
sneak
Jan 24, 2006 09:09 PM
