Kingpins
Old Oct 11, 2018 | 11:14 PM
brian1080's Avatar
brian1080
Kingpins
Anyone put kingpins in a 79 d60? Need info on doing it and best place to get the parts. Mine needs it pretty badly.
Old Oct 12, 2018 | 06:33 PM
mark a.'s Avatar
mark a.
I get a lot of axle parts from Randy's R&P. They may not be the cheapest but they seem to always have the hard to find parts and good customer service. What do you want to know about the axle ?
Old Oct 12, 2018 | 06:50 PM
brian1080's Avatar
brian1080
Just tricks to doing kingpins. I’ve read that they are a PITA and am not looking forward to it.
Old Oct 12, 2018 | 07:17 PM
mark a.'s Avatar
mark a.
They are easy, nothing like a 2wd. All that usually goes bad is the plastic cone and the spring can loose tension.
Old Oct 12, 2018 | 07:47 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Yes on the spring, I just put a real thick washer under my springs. I also replaced the cone once, but in the trucks younger years it saw a lot of river running and mud.
Old Oct 12, 2018 | 08:08 PM
brian1080's Avatar
brian1080
Can you buy just the cone?
Old Nov 9, 2018 | 05:36 AM
brian1080's Avatar
brian1080
Ok, finally got around to doing this. I only replaced the bushings, but will do a full rebuild in the spring.
Old Nov 9, 2018 | 02:06 PM
Aaron-71's Avatar
Aaron-71
I believe Pirate4x4 has a really good write-up on how to do the full rebuild on the kingpins.
I believe mine also need to be done... not looking forward to it either.
Old Nov 9, 2018 | 02:36 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
They are available separately. Found this on the internet.
https://eastcoastgearsupply.com/i-12...0-kingpin.html
Give Dave a call at C & M Gear in Springfield, MO, 417-862-4457. Tell him Moose sent ya. I have been getting my Spicer parts from Dave since the 80's.
Old Nov 9, 2018 | 02:50 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Brian1080, I was thinking about going to the brass bushing the next time I rebuild mine. Since I won't be doing any wheeling in it anymore when I get it put back together.
Dana 60 Bronze Upper Kingpin Bushings - RuffStuff Specialties
Old Nov 9, 2018 | 11:47 PM
black & blue 78/9's Avatar
black & blue 78/9
Balljoint to kingpin
Is it possible to convert a balljoint axle to kingpin. On 4x4.
Is the kingpin THAT much stronger than balljoint?
Old Nov 10, 2018 | 12:28 AM
1TonBasecamp's Avatar
1TonBasecamp
I say no, and no.
But that said, you can also say yes to both.
You can buy Dana 60 king-pin style steering yokes ("inner C" has become the name of choice for most it seems) from Reid Racing seen here: https://www.wildhorses4x4.com/category/s?keyword=reid
Listed for at least three different tubing diameters, the pictures look like ball-joint yokes to me, but maybe that's what they mean by "customizable" maybe?
Notice too, the bronze bushing for the king-pin bearings listed at the bottom of the page. That's a chunk of change for sure, but maybe if you're going through king pin bearing setups regularly and need something stronger, it might be worth it.
Are they stronger than ball-joint versions? From all old reports I'd say yes. But how much, and is it worth changing? I don't know.
Has it been quantified before? Maybe somewhere, but I have not read it yet. Wheelers can break just about anything...
What are you doing with yours black & blue? Using it pretty hard where you need to have the most strength possible? Or simply wanting to upgrade, just in case?
Paul
Old Nov 10, 2018 | 07:13 AM
cstoyer's Avatar
cstoyer
Brian1080
The brass ones from Reid have a much larger surface area and are an upgrade to the nylon ones. I have both the bushings and Reids knuckles for my 60 to install this winter. But keep in mind these are intended to be used with a knuckle kin pin cover that does not have a spring or a high steer arm without a spring. There will be a large diameter bolt that presses on a washer over the bushing that in either set up pre-loads it for proper steering. These are more durable than the nylon ones and reduce wobble in the steering when you go to larger tires but you need the other caps.
cstoyer
Old Nov 10, 2018 | 08:09 AM
brian1080's Avatar
brian1080
I have no plans for brass myself, nylon are cheap and easy to swap.
Old Nov 10, 2018 | 09:52 AM
black & blue 78/9
1Ton
1Ton...thanks for the answer. Me personally, I still have the d44. The question was more for my information and in case someone used search. I would have thought by now a company may have built one for a conversion.
04superduty
Feb 6, 2008 09:15 PM
BLU82
Jun 17, 2007 01:28 AM
75'F-6004x4
16
Aug 25, 2005 10:38 AM
Ryan50hrl
Offroad & 4x4
Oct 7, 2004 03:24 PM
rokfisher
May 1, 2000 08:56 PM
