Battery Help
Old Oct 11, 2018 | 08:57 AM
nick c's Avatar
nick c
Battery Help
86 f250 6.9, bought new batt feb 2018, because of a electrical short in the regulater, the batt has been discharged and charged at least 6 times. I can charge the batt to 13v, batt will lose about .5v per day, in 4 days batt will not start truck, what is the procedure to bring batt back to life.
thanks nick c
Old Oct 11, 2018 | 11:13 AM
tjc transport's Avatar
tjc transport
i ain't rite
if the disconnected battery is loosing enough that it is dead after 4 days, i would return it for warranty replacement.
if it dies after 4 days while hooked up to the truck, than there is a problem in the truck.
Old Oct 11, 2018 | 11:34 AM
ford390gashog's Avatar
ford390gashog
You didn't mention it but where the batteries replaced as a pair? Your battery isn't designed to be discharged completely and the damage is not reversible. You should warranty the battery and fix your charging issue.
Old Oct 12, 2018 | 12:16 AM
hairyboxnoogle's Avatar
hairyboxnoogle
^ As he touched on, the batteries MUST be replaced as a matched pair. Sounds like you need to track down the draw. Usual suspects are voltage regulator and radio.
Old Oct 12, 2018 | 09:54 AM
Olds64's Avatar
Olds64
You can isolate the parasitic load by pulling fuses. Put an amp meter in series with the battery with the key off and you should have 0 A of current draw. If you have mA of current draw with the ignition off pull fuses individually until the current draw drops to 0.
Old Oct 12, 2018 | 06:43 PM
nick c's Avatar
nick c
found short, it was a bad voltage regulator, took batt back and they replaced it.
thanks, nick c
Old Oct 15, 2018 | 08:22 AM
Olds64's Avatar
Olds64
Good to hear. I love parts with a warranty.
RV_Tech
Electrical Systems/Wiring
Oct 28, 2013 09:38 AM
KelVarnson
Feb 21, 2012 10:11 AM
medic92
2004 - 2008 F150
Feb 6, 2008 08:57 PM
SproutW
1978 - 1996 Big Bronco
Aug 4, 2007 03:08 AM
tealboy1
1997 - 2003 F150
Oct 18, 2005 05:49 AM
