starter solenoid sticking
on
got her down off the jackstands, where she's been sitting for months and months... gas in the tank ...little gas in the carb and fired it up.. started right up but found I need to adjust carb floats (Quick Fuel 650)...little bit of over flow thru vent tubes.. so I shut it down...
Next try the starter solenoid stayed latched in . Luckily it didn't fire off.. killed the switch and it still turned engine.... slid under it and banged on the solenoid and it released.... Now my question is... what makes a solenoid stick ??? never had one do that. It's a new one so it should be good, right ???
yea, I know... little help ???
joihn
joihn
on
dont think so... no separate starter button... starter solenoid is straight off the ignition switch. Cut off the switch and even removed the key and it still cranked... slid under it and hit the solenoid case with a wrench and it clicked off... seems like it's a common problem
looking for a better hi-amp solenoid now...,
john
john
I had a brand new Motorcraft solenoid stick about two months after installation on a Mustang. Fried the starter and the battery cables. I have a separate battery disconnect switch on the positive cable now. Can’t tell you why they stick. Had a voltage reg stick on my truck after shutdown and it fried the generator. Now the truck has a battery disconnect too!
john
john
Standard High Current Relays - Littelfuse
John,
I take it this is the style of starter with the solenoid mounted on it? Is this a new or old starter?
It could be either a mechanical issue or an electrical issue. Mechanically, if its an older used starter with the solenoid mounted on it, the plunger can hang up inside the solenoid. Typically when these stick its the opposite situation where the starter won't work until you smack it with a hammer. The plungers are supposed to be able to freely rotate inside the solenoid, if they get where they don't rotate they can get a wear mark in the barrel of the plunger which can cause the stickage.. That or the pivot between the solenoid plunger and the starter gear might be hanging up.
I guess there could also be the case where the contact disc inside the electrical end of the solenoid could stick to the contacts keeping things engaged.
You might make sure that electrically, your ignition switch is only supplying a positive signal to the starter in the Start position.
Good luck
Bobby
Good luck
Bobby
All the current reproduction solenoids use copper coated steel contacts and easily arc out under low voltage high amperage situations. The above poster linked to heavy duty alternatives and while expensive they are worth it. Those are the style still used in golf carts and off highway equipment and have a much higher rated duty and cycle time.
Modern starters (those with integrated solenoids) do not need the external OEM Ford relay. In fact, if you run an external relay you are adding a delay into the circuit that makes the release of the starter Bendix out of sync with the release of the ignition key in start mode. In my experience, hanging starters are a result of poorly aligned Bendix gears and not a solenoid problem. Good luck, either way your new starter should correct the problem. I am running an MSD starter on my 351 and like it a lot.
jxnslotcar
23
08-18-2020 02:53 PM
rhrmusic
04-30-2006 12:02 PM
