1950 vent window
Old Oct 8, 2018 | 01:32 PM
olguy317's Avatar
olguy317
1950 vent window
Hi, starting on my door window/rubber seal replacement. I've removed everything from the doors and would like to begin by refinishing internal metal parts. Can anyone tell me if the vent window/frame assembly comes apart from the outer frame (which the replacement rubber mounts on) The top pivot is held on by two screws...no problem, but the bottom pivot seems to have the washer and stop pressed on to the square shaft. The tension adjusting locknut and spring came off fine, but the thick washer seems to be pressed on the shaft. Is it just rusted together or is it pressed on? Don't want to destroy it taking it apart.
Thanks for any help
Tony.
Old Oct 8, 2018 | 02:32 PM
olguy317's Avatar
olguy317
Please ignore the above post. I found a previous post that explained all. Thanks
Broncor
Jan 23, 2019 06:09 AM
66F100Again
Jul 26, 2016 07:55 PM
scottddove
Nov 17, 2008 11:52 AM
ole yeller 1978
Sep 4, 2006 12:20 PM
NewMexF250
Sep 2, 2004 12:42 PM
