Door key pad code
Old Oct 7, 2018 | 06:06 PM
ArmamentDawg's Avatar
ArmamentDawg
Door key pad code
Where can I find the factory door key pad code other than the Capt. Obvious wallet cards. Bought the truck used and want to reset the code.
TIA
Old Oct 7, 2018 | 06:32 PM
Wiggums's Avatar
Wiggums
You can't reset the code. You can add a code on top of the factory code though.
You would have to take it to the Ford dealership if you don't have the card then they need to plug it in a computer and they'll have the code.
Old Oct 7, 2018 | 06:38 PM
Wiggums's Avatar
Wiggums
My bad.. I looked around and found a way so you don't have to take it to the Ford dealership... here you go...
Old Oct 7, 2018 | 07:26 PM
Labmaster02's Avatar
Labmaster02
I believe its also located above or behind the passenger side kick panel.
Old Oct 7, 2018 | 08:25 PM
Skylaneman's Avatar
Skylaneman
That's a good solution for those with keys. But any way to do it if you have push button start?
Old Oct 8, 2018 | 01:26 PM
GlueGuy's Avatar
GlueGuy
Hrrrmmm... Maybe you push the start button with your right hand, then switch to the left hand...
Old Oct 8, 2018 | 01:36 PM
ford390gashog's Avatar
ford390gashog
You can recover it in forscan. Just select all the digits and press play.
ZiggysMom
2009 - 2014 F150
Dec 8, 2017 02:46 PM
richf150lock
2009 - 2014 F150
Oct 12, 2017 06:06 PM
JoeDirt68
Mar 15, 2010 04:29 PM
Harley320
Aerostar
Nov 8, 2008 05:53 PM
gp_supercrew
1997 - 2003 F150
Aug 17, 2006 02:16 PM
