Help! Key won’t engage starter
Old Oct 7, 2018 | 10:48 AM
cwerner01's Avatar
cwerner01
I have a 1990 f150. The key switch has always been tough to turn and sometimes I will have to take the key out and try a couple times before it starts. Sometimes it will hang up after it starts and not return, almost has a “sticky” feeling to it. The past week it has gotten much worse, and I can not start it at all anymore. So I pulled the lock cylinder and replaced it and it didn’t fix it. So now I got an ignition switch ordered and working on pulling out the old one. My question is is this probably the issue or could it be the neutral safety switch and if so where is it located? I checked around the clutch pedal and could not find it.
Old Oct 7, 2018 | 11:05 AM
lisagoud's Avatar
lisagoud
key not engaging starter
I've had this problem on numerous of m y 1989 f series trucks. I have always replaced the rod and the lock ignition module on the base of the steering column to fix this problem. However, I just picked up a 1989 F350 dually where this [problem was present for the old owner. He fixed the issue by installing a push button on the dash with straight 12 volts w going to the s terminal of the solenoid. works great,
Old Oct 7, 2018 | 11:21 AM
cwerner01's Avatar
cwerner01
What rod did you always replace? The actuator?
Old Oct 7, 2018 | 11:48 AM
lisagoud's Avatar
lisagoud
actuator rod
yes the actuator rod
conrad10781
13
Nov 27, 2024 04:24 AM
oravecz1
1978 - 1996 Big Bronco
Aug 22, 2017 06:44 PM
Smills48
Mar 19, 2014 05:20 PM
tem
Electrical Systems/Wiring
Dec 17, 2006 04:52 PM
WHEX7777
Jan 13, 2003 09:42 PM
