Spark knock during tip in on throttle
Long story short, been fighting the occasional ping/rattle on the truck for a long time. Was a 95 day and while pulling my trailer I started hearing spark knock for a split second while I accelerated from a stop. It does it in neutral and drive. Gauge does not indicate overheating (warm but not bad). Haven't checked plugs for awhile, fuel pressure is in spec. I drove with the SPOUT disconnected and it seemed somewhat better but it still does it. Truck runs smooth still. Checked codes and got 634 which I presume is unrelated (mlps code). Overall, I'm stumped. Really hoping it will hold together until I get it fixed but what should I be checking?
Pull the injectors and take a look. Some have posted how they rigged up a 9V battery to energize an injector. Use a bottle filled with cleaner and an adapter to fit over the top of the injector, squeeze the bottle while activating the injector. Watch the pattern. Or send them off to be cleaned and tested. Or do it yourself.
Well, I put in some ASF32 plugs (SP415A) which are a heat range lower than what is specified. I didn't have the SP450A available at the time ... So it runs about the same but I swear the tail pipe is making my eyes water, nose burns like it's running rich ... Could being one range colder on plugs cause this? Don't think it was doing this before. If so I'll order the specified plug.
