Question about sun visors
Old Oct 10, 2018 | 09:10 PM
march's Avatar
march
I found it helps to screw a drywall screw into the end of the broken pin. This will allow you to get a pair of vice grips on the screw and work out the pin.
Old Oct 11, 2018 | 11:16 AM
beartracks's Avatar
beartracks
Not to hijack but I replaced all the visor parts on my 77 and all is good. (from Carpenter) except they are not tight enough. I've tried various things to wrap around the hinged pin with no success.
Old Oct 11, 2018 | 11:19 AM
paulstruck's Avatar
paulstruck
the rattling is going to drive me crazy. What did you do about the metal vs plastic pin issue? Did you use the metal pins with the rubber boot, or did you manage to pull the metal pins out of the visors and replace with the plastic pins?
Old Oct 11, 2018 | 11:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D0DZ-6204114-B .. Visor Anchor Pin-Gray Plastic-Includes Rubber Tip (also available separately) / Reproduced
1970/75 F100/350; 1976 F100/350 before serial number A50,001 / 1970/74 Econoline.
1970 Galaxie/LTD/Fairlane/Torino/Mustang/Cougar/Falcon/Maverick/Comet/Thunderbird; ditto 1971 + Pinto/Bobcat before production date 5/3/1971.
D6TZ-1004114-A .. Visor Anchor Pin-Chrome / Reproduced
1976 F100/350 from serial number A50,001; 1977/79 F100/350; 1978/79 Bronco.
D1DZ-6204115-A (replaced C5AZ-6204115-A) .. Visor Anchor Pin Rubber Tip / Reproduced
1967/79 F100/350; 1970/79 Bronco & Econoline / 1965/78 FoMoCo Passenger Cars; ditto 1979 except LTD/Grand Marquis.
Old Oct 13, 2018 | 12:46 PM
78Hayride's Avatar
78Hayride
I got around to replacing my visor pins today. I pulled a plastic one out of passenger side using a drywall screw. It came out in pieces. The one on drivers side was wood. Replaced both with LMC gray plastic.
jgilrfr
May 22, 2011 12:15 PM
hp246
Apr 2, 2010 08:26 AM
Rando Commando
Mar 31, 2010 05:00 PM
WMRiceman
Mar 30, 2007 04:14 PM
