Another Hinge Pin question
Old Apr 1, 2010 | 04:50 PM
hp246's Avatar
hp246
I searched the forum and found a bunch of questions on where to find the pins. I found several sources. My question is related to installation. I'd like to do the install without pulling the doors. Most of the aftermarket pins come with an E clip to lock them in place. None of the Ford Pins I've found have the E clip. Is it possible to somehow peen the pin after its been installed? Even the guys at Bronco Graveyard were surprised when they pulled one and it didn't have the E Clip. The response was that I could machine the Pin for the E clip. There's got to be a better way.
Old Apr 2, 2010 | 03:09 AM
wdfp's Avatar
wdfp
Maybe just do one hinge at a time, and possibly spot weld a washer on the end of the pin after installation . That is if I am reading this correctly
Old Apr 2, 2010 | 05:29 AM
duste's Avatar
duste
No pins I have removed from older ford doors ever had clips either. You could cut a groove for a clip with a hacksaw pretty easy though or just put a spot of weld on the bottom of the pin once it's installed, it wouldn't take much to keep them from working thier way out.
Old Apr 2, 2010 | 08:19 AM
hp246's Avatar
hp246
Yep, you read correctly. I knew to originals weren't clipped, but I believe they were peened at the factory to keep the pin from popping out. I like the washer idea. sounds like it will keep everything neat.
Old Apr 2, 2010 | 08:26 AM
wdfp's Avatar
wdfp
I know it worked for me a few years ago on a 76 supercab.. remember to blocck the door up though so it doesn't fall and bend something.. Really not that big a deal to take it plum off though..
19704X4F250
1983 - 2012 Ranger & B-Series
Sep 26, 2013 12:33 AM
Choncer
Aug 21, 2010 09:35 PM
Abzack
Jul 7, 2010 07:05 PM
PSNut
Oct 18, 2009 04:31 PM
Mike G
Feb 5, 2004 12:01 PM
