time for a new look!
Old Oct 4, 2018 | 10:41 AM
PrescottIce's Avatar
PrescottIce
Originally Posted by pirate4x4_camo
I’d suggest when you go to the no block setup drive it without a rear sway bar and see how you like it. I ended up permanently removing mine because it was not needed. No body roll to speak of and not worth the the give up in ride quality for what little body there is.
Degree shims... depends on what type rear shaft you have.
I have a single joint at each end and if I wasn’t switching to a Double Carden shaft I would need a shim.
As much of a PITA it is to take apart it’s best to do the install and spec out your angles to see exactly what shim you may need.
I don't anticipate adding a rear sway bar at this point. Sorry I failed to specify, but my concern was over the front sway bar... a 2-3" increase in ride height, not sure where that will put the sway bar.
I also have single joints at each end. Not that much extra work to do the install and then measure/install the appropriate shims. I want to maintain drivability to the greatest degree, so doing it right is paramount. Well, within budget, which rules out upgrading to double Cardans. Maybe when the splines in the old one get sloppy...
Old Oct 4, 2018 | 10:57 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Originally Posted by rickelrod
I guess I should start with the wheel/tire combo?
Rick
That is the logical place to start when making suspension changes.
Old Nov 13, 2018 | 07:02 PM
rickelrod's Avatar
rickelrod
Pirate,
So I finally pulled the trigger on a wheel/tire combo. I settled on the Moto metal Mo970 Black with milled spoke windows in an 18x10 -24 and Nitto Ridge Grapplers 35x12.5R18LT. I like the way Smackdaddys EX sits on the same size wheel/tire with 4inches in the front and 5 inches in the rear. Would the same Procomp springs apply? What shocks would be needed at this lift. I appreciate all the help.
Rick
Old Nov 13, 2018 | 08:00 PM
IMASAP's Avatar
IMASAP
Additional hardware,
If you want airbags then we will need to solve for that since the standard Excursion kit will need some mods to work.
you would likely get the F250 kit and add a Daystar mount. If you decide to go this route I can look it up and work through the issues with you.
PMF to the rescue
Airbag Tang Ubolt Top Plates
Old Nov 13, 2018 | 08:35 PM
Psyclopse's Avatar
Psyclopse
Originally Posted by PrescottIce
...but my concern was over the front sway bar... a 2-3" increase in ride height, not sure where that will put the sway bar.
I did THIS MOD and it drops the upper mount point by three inches, using the factory Excursion links.
Old Nov 15, 2018 | 12:37 PM
rickelrod's Avatar
rickelrod
Pirate,
Rick
kawasakiklx1
Jul 11, 2017 11:48 PM
rlh68050
2009 - 2014 F150
Sep 28, 2010 12:50 PM
Will Bite
Aug 12, 2010 04:52 PM
lottsaquestions
Jan 23, 2009 02:54 PM
mickster
Jun 23, 2001 10:40 PM
