SEALS
Old Oct 2, 2018 | 09:59 AM
F-250 restorer's Avatar
F-250 restorer
SEALS
If I have an input shaft seal, yet need that seal to accomodate a slightly larger shaft. how do I get/order/find it?
Does anyone have a seal site they use? Do I simply give them the # on my seal and tell them what I need?
Thanks for your help
Old Oct 2, 2018 | 10:31 AM
ranger140892's Avatar
ranger140892
Grumpy goat
Input shaft seal for what? Assuming you're talking transmission. Which transmission? Without that info, my first thought would be that whoever made/sold the oversized shaft would have the oversized shaft seal.
Old Oct 2, 2018 | 10:58 AM
F-250 restorer
Thanks for the reply. It is the input shaft seal for a zf5. Rather than buy what may be Chinese shaft for $100--$265, I bought a repair sleeve for $20. I know that the #s on a seal tell the dimensions. I just need to know of a co. specializing in seals, so I can order a bit larger. Thanks.
Old Oct 2, 2018 | 12:37 PM
somethingclever's Avatar
somethingclever
who made your speedi sleeve? Do they also make seals? (SKF?)
Old Oct 2, 2018 | 02:21 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
If it is a standard speedi sleeve, they use the stock seal.
Old Oct 2, 2018 | 02:39 PM
F-250 restorer
Well, maybe I need to lube it with some stp. I tried to lube with ATF, which is what the zf uses, and it about pulled the rubber out of the metal ring of the seal.
Old Oct 2, 2018 | 02:58 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
You did get the speedi sleeve in the correct place and removed the flange, Unless flange was bottomed on the shaft. correct?
Got any pics?
Old Oct 2, 2018 | 04:04 PM
mark a.'s Avatar
mark a.
They will need the shaft size as well as the inside diameter of the bore it's going in.
high ho silver
Escape & Escape Hybrid
Mar 19, 2011 09:54 PM
northwoods1990
Jul 19, 2010 08:36 AM
blakebuckley
Mar 24, 2010 09:09 PM
