Need help
Oct 1, 2018 | 03:35 PM
Need help
my 2006 f250 6.0 power stroke won’t turn over or anything I’ve checked fuses I can’t figure out why it won’t start
Oct 1, 2018 | 03:36 PM
Oct 1, 2018 | 03:41 PM
I’ve checked the batteries but if I by pass th and get it started will it charge the batteries and will I have to worry about it running away
Oct 1, 2018 | 03:50 PM
I’m having a no crank issue
Oct 2, 2018 | 07:55 AM
How did you ”check” the batteries? Removing them and having them load tested individually is the best way to know if the batteries are really good. After that I would check the grounds to the frame. Check fuses with a test light.
Oct 2, 2018 | 08:43 AM
No crank at all?
Try starting in neutral
Check key start .. Try another key
Security Alarm System? Kill starter?
Oct 2, 2018 | 08:54 AM
Try this and see if the truck has the ability to crank.
Oct 2, 2018 | 09:59 AM
Will a dead key battery or defective key prevent the vehicle from turning over?
I had an 06' with the older type key. I never tried starting with the battery removed. Hmmm...
I also had a VIPER alarm system with starter kill relay. If it went bad, I guess that could cause a problem.
Oct 10, 2018 | 06:26 PM
Will turn over but won’t start and it blows the pcm injector fuse under the column and I’ve replaced the pcm and it still blew the fuse
Oct 10, 2018 | 08:44 PM
Twice you say it doesn’t turn over, then later you say it turns over but doesn’t start?
Did you do something to make it turn over?
Oct 11, 2018 | 06:13 AM
Well it will turn over once I put the pcm fuse that keeps blowing but once it blows it won’t do anything afterward
sherrydc3
Dec 23, 2018 08:36 PM
Cstarwalt
Sep 24, 2018 11:42 AM
12F350
Aug 14, 2018 03:06 PM
Duke86
Mar 18, 2018 04:35 PM
teddyinastroker
Oct 29, 2012 08:53 AM
